Boatanchor
- Joined
- Jul 17, 2011
- Messages
- 991
I've noticed that some of my VHF 12.5Khz step frequencies are intermittently being altered to a nearby 5Khz frequency.
For example, program in a conventional frequency of 166.8375Mhz and it works for a few days, then for no apparent reason, the audio starts to sound a little distorted and when I look at the frequency, it has changed to 166.835Mhz (the nearest 5Khz increment).
The Bandplan is set to USA which should force 12.5Khz steps on this band.
Interesting thing is that after this happens, it is impossible to enter the 'Object Editor' mode and enter the correct frequency again. You enter 166.8375 and hit select, the system accepts the frequency, then you go to Save the object configuration and it reverts back to 166.8350Mhz again. Even if you go in and enable 'Flexsteps', the scanner will only accept 5Khz increments.
You can however enter a 5Khz step frequency, so if I enter 166.825Mhz, the scanner is happy with that and will accept it.
The only way you can get the correct 12.5Khz increment frequency back in is to use the PC programming utility.
Bizarre...
These things do appear to be a quirky radio with some rather dodgy (and presumably now unsupported) firmware. No wonder RS was offloading them cheap
I wonder if the WS-1080 and PSR800 do the same thing??
Bizarre...
