Pro-652: New scanner help
drbone30
wabash IN
well first off I went from a pro 2096 to the pro 652 and what a shock LOL !!!
I downloaded my citys talk groups and freq to scanner but now it say nothing enabled with a G above it , what did I do wrong ? and yes ill need more help as I go along so bare with me
Spitfire8520
I might be completely clueless! =)
Colorado
What software are you using to program your Pro-652?
My first reaction without much more detail is that you probably downloaded everything, but didn't assign to them to a Scan List. Scan Lists are enable these using the number buttons on the keypad. If you didn't assign them in software, then enabling and disabling these Scan Lists will not change the "Nothing Enabled" message. To fix this, you need to go in and assign the TGRP or CONV objects to a Scan List before you can listen to them.
Here are some guides for ARC500 and WIN500 if you use either of these.
ARC500 User Guide - The RadioReference Wiki
WIN500 - UtahRadio
drbone30
wabash IN
thanks for your response . I didn't have it assigned , went and join RR and downloaded it thru the website . its a little harder then my old pro 2096 ..
