I thought I came across a thread here where someone mentioned knowing how to reset a 668 to factory firmware, but haven't been able to find any instructions. Can someone post that if it is available?
I'm not talking about the factory settings in software, but the factory firmware. I paid someone to do it a few days after I made the mistake of purchasing the thing, but when I hooked it back up to the software, it showed the latest firmware was still installed. Showed same on the scanner screen itself.
The thing is pretty much useless at this point. Leave it on for more than an hour it crashes. Leave it plugged in with USB, on or off, it crashes. Once it crashes, have to take batteries out and wait a couple hours, then reinstall batteries and it will work, The only way I can get it to work, is to baby it with a big supply of charged batteries, which take longer to charge than they last in the scanner, and only use it for limited time. Have tried changing the SD card, reformatting with a card reader and better program other than Win7 or RS software, no go.
