Since Radio Shack went under where can i get rechargeable batteries for the pro 106 scanner
I get mine from amazon. Eneloop and eneloop Pro's .
Powerex 2700.. Absolutely the best.. longest life in your scanner.. just my 3 cents..
Doug
Your enercells are probably cashed if you've been leaving them in your pro-106. I wouldn't do that with your next set. As others have said, Eneloops and Powerex cells rock! . 73, n9zasNewbie here.
I'm using enercell rechargeable's in my Pro-106. I keep the scanner plugged in to listen, every time I disconnect and go in the back yard ,it dies within minutes. I'm guessing keeping it plug in, is not charging the batteries?
I'm going to Costco's and buy a charger and batteries. Thanks,
John
I use a La Crosse BC700 Charger, I never ever charge batteries in a scanner.Do you ever use the charger that came with your scanner Or do you just use an ext. charger for your batteries?
