wltrsf
- Joined
- Nov 28, 2004
- Messages
- 25
Hello, my first post in a long time. Here is my problem. I have both the 651 and 652 that I bought for about $250 when RS was closing a lot of stores. The town I live in, Littleton Ma operates on a repeater with an output of 155.85 MHZ with a PL of 151.4, which worked fine on my PRO-96. When I first programmed the scanners I realized I wasn't hearing them anymore. So I programmed the input freq with the same PL and heard the mobile units just fine. Then I decided to put in an additional channel with the same freq. ,155.85, but no PL just search mode. After this the scanners began to pick up the transmissions again. However if I stored the 151.4 PL it finds it again missed everything. Then I found if I put the scanner in manual mode and park it on this freq with 151.4 PL on it receives everything. This is very disappointing to me, after all how would I know what other conventional frequencies I could be missing? I wonder if anyone has encountered this kind of problem before? Is this a case of you get what you pay for?
