Easy Peasy. You plug the stereo plug of data cable into the PCIF jack on the upper right side of the scanner, then the USB into the PC. Turn the scanner on, open up your software. Click on the Scanner Tab, click on Upload to scanner. You will then overwrite anything in the scanner. Activate the Scan List #'s you want to scan.
Larry
