Where can I find a data cable to connect to a pc for the PRO 2055? Also what software is best for loading this scanner. Wow not sure I can do this manually.
Yes I have that manual, however still a little much with P25 for me. Thanks will post in illinois
. Sure you can! That's what the keypad is for, no software needed. . 73, n9zasWhere can I find a data cable to connect to a pc for the PRO 2055? Also what software is best for loading this scanner. Wow not sure I can do this manually.
I'm pretty sure that the PRO-2055 can't handle P25.
Thanks understood 396xt phase 1 only. Thanks
