Howdy y'all. I just picked up a Pro 651 from a pawn shop fairly cheap. I was excited to have another digital scanner. I live in El Paso, Texas. The city uses P25. I am able to listen on both my Pro 652 and my Uniden BCD396XT without any issues. I have programmed the Pro 651 manually, through ARC500 and win500. I have even cloned from my 652 to my 651 directly. Nothing seems to be working on being able to listen to the P25 system here. I have looked up and tried various expert settings that I have found on the forum but nothing works. Though I did get my RSSI bars working. When I analyze the trunking, I am able to go to the known control channel and I can pick it up no problem. The scanner isn't classifying it as a P25 channel though. I am starting to think that the previous owner messed up the setting and wasn't able to get it back to normal so they pawned it. Eitherway, Does anyone have and/or know what working settings should look like? I reset back to factory by holding PGM as I turn on and pressing 1 and then doing it again pressing 0, but those setting seem to break a lot. I am running version uP App ver 2.9. DSP AppVer:RF1.4, DSP VocVer:1.0.
Any help is appreciate. I appologize before hand if it my post isn't as coherent as it should be. I am frustrated with this thing. Thanks in advance!!!
