Joseph11
- Joined
- Nov 17, 2004
- Messages
- 2,270
Has anyone noticed a difference in the hardware between different versions of the PRO-651 and PRO-652? I have a Win500 configuration I've used for years on my PRO-106 and since 2014, my PRO-652 (manufactured the middle of 2014), without any issues. I recently picked up a PRO-651 (manufactured the end of 2015) and noticed after uploading my Win500 configuration to it, the RSSI bars were barely showing anything even if a full strength signal was being received. After resetting the scanner and reading the default configuration into Win500, I noticed the RSSI bar thresholds were significantly different than what worked on my PRO-106 and PRO-652. Both the PRO-652 and PRO-651 are running the latest firmware as per RadioShack's website. Does my PRO-651 have some hardware change(s) that the PRO-652 didn't have? Does anyone know of any variances between models of these scanners manufactured between 2014 and 2015? I could see these differences existing between the GRE manufactured PRO-106 and the Whistler manufactured PRO-652, but not between the PRO-652 and the PRO-651. Thanks.
