Closed Thread
  #461 (permalink)
Old 01-10-2017, 6:18 PM
Hello,
Link is at the bottom of the Main Wiki page for the project.
https://github.com/LinuxSheeple-E/GREFwTool/wiki
73 Eric
  #462 (permalink)
Old 01-10-2017, 6:20 PM
buddrousa's Avatar
Read the post above you it is still active.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #463 (permalink)
Old 01-10-2017, 6:41 PM
milcom_chaser's Avatar
Originally Posted by gaushouse View Post
Can someone please send the link that to the tool to burn the 1080 firmware into the radio to update the radios software.
Thank you in advanced.
See post #445 above for download link for all 3 files.
  #464 (permalink)
Old 01-10-2017, 6:42 PM
Thank you
  #465 (permalink)
Old 01-11-2017, 1:19 AM
Paco-Jerte's Avatar
Here is a faster way to download all 3 files needed with no timer or download limits reached nag.
Dont forget to unzip them once downloaded. If this has helped you, you can thank me as a response here on this thread.
Zippyshare.com <===== click this link
tons of scanners why list them huh
  #466 (permalink)
Old 01-11-2017, 6:46 AM
tumegpc's Avatar
I'm getting a warning when I click on the link
Malwarebytes has blocked a potentially malicious website.
SCANNERS:
Whistler TRX-1/ TRX-2 with DMR - NXDN fully supported
Uniden 536HP/436HP with DMR - { NXDN not supported }
Uniden Home Patrol 2 { DMR- NXDN not supported }
  #467 (permalink)
Old 01-11-2017, 6:51 AM
sibbley's Avatar
That's because it's a file share site. Download and scan with anti virus if you want to be sure.
Too many scanners and radios to use at one time, But I'm trying!
  #468 (permalink)
Old 01-11-2017, 9:39 AM
trp2525's Avatar
FYI I downloaded and then scanned the file with the latest version of Kaspersky Internet Security and the "668 upgrade.rar" file is clean.
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, PRO-668 (officially upgraded to WS1080), TRX-2, BC950XLT, BCD996XT, BCD396XT, Motorola Minitor II, Antenna Specialists MON731
  #469 (permalink)
Old 01-11-2017, 9:59 AM
rgchristy's Avatar
Same antivirus results here, however, it took three tries to get the actual download to start. On the first try, a new window popped up, requesting that I install a "privacy add-on". Closed the window promptly.
The second try asked me to join Zippyshare movies. Again, closed the window.
The third try started the actual download.
Just an FYI.
  #470 (permalink)
Old 01-11-2017, 9:10 PM
Default PRO668/WS1080 instructions?
Am about to 'take the plunge' and convert my 668 to the 1080. My question is, which manual should I now use for references? Is it 100% now going to be a WS1080, according to the ( Easier to Read Whistler WS1080/1088 Handheld Scanner and Software Manual ) manual? Thanks!
  #471 (permalink)
Old 01-12-2017, 10:45 AM
Hello,
You need to use the WS-1080 Ez-Scan software and follow the WS-1080 manual. Do not use Ez-Scan to update the CPU software, other updates are okay.
The Pro-668 firmware uses slightly different menus, with some items labeled differently.
73 Eric
  #472 (permalink)
Old 01-12-2017, 4:33 PM
6Paul21's Avatar
Having a little problem loading DMR into 668. Followed all instructions and screen on 668 has
uP BootVer:RF1.1
uP Appl Ver:U3.8
Getting everything fine except DMR and this shows no signal strength bars and PSR 800 gets everything fine. Where have I gone wrong.
Thanks Ed
Sarasota County Fire Department Photographer
  #473 (permalink)
Old 01-12-2017, 4:50 PM
kd7ckq's Avatar
Update your DSP Firmware in the WS1080 software. Do not update CPU.
from pg12 instructions.
7) Go into ezscan (NOT iSCAN) do the DSP UPDATE, library updates and/or restore from archive or. transfer database if needed. via the cable or card reader DO NOT ALLOW A FIRMWARE UPDATE UNTIL FURTHER NOTICE AND TESTING SHOWS ANOTHER FIRMWARE WORKS 100%
  #474 (permalink)
Old 01-12-2017, 4:53 PM
trp2525's Avatar
uP BootVer:RF1.1
uP Appl Ver:U3.8
Thanks Ed
In addition to updating the CPU firmware to version 3.8 on your PRO-668 you didn't say if you also updated the DSP firmware to version 3.0. If not, you have to update the DSP firmware on the PRO-668 for DMR to work and you do that by using the Whistler EZ Scan PC program (NOT the Radio Shack iScan PC program).
trp2525
  #475 (permalink)
Old 01-12-2017, 5:06 PM
kd7ckq's Avatar
uP BootVer:RF1.1 Oops, My bad. See below
uP Appl Ver:U3.8 <-- This is your CPU Firmware you updated with GREfwTool
Thanks Ed
Hope this helps.
  #476 (permalink)
Old 01-12-2017, 5:41 PM
6Paul21's Avatar
Hello guys, when I go into EZScan I get Scanner DSP 3.0 and Available DSP unknown.
Checking all Firmware and on Check for updates
EZ Scan 2.17 BLD 460 Pending-Pending
CPU Firmware 3.8-Pending-Pending
DSP Firmware 3.0 Pending-Pending
I was able to be successful on DMR on Pro18 & PSD 800's
This is all done in Whistler 1080.
  #477 (permalink)
Old 01-12-2017, 5:48 PM
kd7ckq's Avatar
try again. mine did the same thing about 30 min. ago.
Your scanner should look this.
uP Appl Ver: U3.8 <--- This is your CPU Firmware. Do not update ever.
DSP Voc Ver: 1.6
DSP App Ver: 3.0 <--- This is your DSP Firmware. Make sure it is 3.0 (released December 15, 2016) Upgrade this in ezScan software.
DSP build#: 101
  #478 (permalink)
Old 01-12-2017, 5:49 PM
tumegpc's Avatar
Downloaded and you are correct , no problems . thanks
SCANNERS:
  #479 (permalink)
Old 01-13-2017, 9:34 AM
Default Getting "File does not exist"
Following the link provided, I'm getting "File does not exist on this server". Tried from 2 different computer, 2 different OS version, same result.
Has the archive been removed?
Thanks in advance for help with this.
  #480 (permalink)
Old 01-13-2017, 9:41 AM
trp2525's Avatar
Has the archive been removed?...
Probably was removed from the server due to copyright issues/concerns.
trp2525
Closed Thread
