  #861 (permalink)
Old 03-19-2017, 10:33 AM
Originally Posted by DJ11DLN View Post
At the risk of offending you, I'm just going to say, "Don't be greedy." My attitude is that both of my RS scanners work far better now than they did with their stock FW. I had to give up on the Pro-18 after Grecom left the scanner business, and on the -668 after the RS bankruptcy kerfuffle. Eric's hard work gave both of them new life. The -18 did not even have p.2 decode, record, all 200 scan lists, any V-scanner folders, and the list goes on. For me, this is all pure gravy and I refuse to take the attitude that future Whistler updates "should" be made compatible with my RS radios...regardless of who built them.
Sometimes, "enough" just has to be enough.
WELL SAID!!!! Thank you DJ11DLN, and a huge thank you to Eric!!!!!
Whistler TRX-1, Radio Shack Pro-668 (mod), Pro-197, Pro-651, Pro-106, Pro-96
Baofeng 888, UV82, UVB5, Connect Systems CS750
  #862 (permalink)
Old 03-19-2017, 6:05 PM
Hamradiostuffing's Avatar
Thumbs down
We have been down this road before and I do not see good reason to go there again. I have stated my position before and I have nothing to gain by going there.
  #863 (permalink)
Old 03-19-2017, 7:49 PM
Hello all,
I last did the Whistler 3.8 FW to my 2 RS-668 but managed to just now miss the window of time with the new driver and 4.5 GrefwTool process that would download direct from Whistler. So now I believe I need to ask one of you for a PM and a link to the 4.5 bin, and use the process I used with the 3.8. After I receive the 4.5 from someone, will I be okay then to use the older GREFwToolWin0.1.0.2.exe and point to the local copy of 4.5 bin file, as the instructions were with the 3.8? And will I need a newer driver and latest ez-scan with the 4.5 vs. the 3.8? Please send me the 4.5, and answers to the previous questions.
Thanks in advance,
ScottPDX
  #864 (permalink)
Old 03-19-2017, 8:01 PM
Originally Posted by ScottPDX View Post
Hello all,
Thanks in advance,
ScottPDX
Hello,
You need the latest version of GREFwTool to use Version 4.5.
73 Eric
  #865 (permalink)
Old 03-19-2017, 8:05 PM
Ok. Thanks. Can I ask someone for a PM for the 4.5?
Thanks,
ScottPDX
  #866 (permalink)
Old 03-19-2017, 8:33 PM
Thanks, all. I have the 4.5 bin file now.
Appreciate everyone's effort on keeping the PRO-668 viable.
ScottPDX
  #867 (permalink)
Old 03-20-2017, 9:30 AM
Can somebody please send me the 4.5 bin for the WS1080
  #868 (permalink)
Old 03-20-2017, 9:37 AM
If someone could send me the 4.5bin it would be greatly appreciated.
  #869 (permalink)
Old 03-20-2017, 9:45 AM
Could someone send (PM) me 4.5 bin? The Whistler site is down. Thanks in advance.
  #870 (permalink)
Old 03-20-2017, 10:24 AM
Temp download of 4.5 https://www.filemail.com/d/srgugrpimoyscle
  #871 (permalink)
Old 03-20-2017, 10:53 AM
DJ11DLN's Avatar
Originally Posted by Wackyracer View Post
Thank you! I somehow goofed saving it after I updated my radios last time. Now I've got it properly saved and archived to my backup drive.
If it looks stupid but it works...it ain't stupid.
  #872 (permalink)
Old 03-20-2017, 10:59 AM
I think you find that the sensitivity will be much better with version 4.5.
  #873 (permalink)
Old 03-20-2017, 11:15 AM
DJ11DLN's Avatar
I already had 4.5 on my radios...I somehow either managed to goof saving the FW after updating or else I somehow accidentally deleted it. Life as a thumb-fingered idiot is a real drag sometimes.
And I agree, sensitivity is even better with 4.5. Did I mention that I'm a happy camper since Eric worked his magic?
  #874 (permalink)
Old 03-20-2017, 11:19 AM
you me both I have dmr now and listen to the local ham dmr machines.
  #875 (permalink)
Old 03-20-2017, 12:44 PM
Thank you for the link WackyRacer!!!
  #876 (permalink)
Old 03-20-2017, 5:54 PM
I join the few (so far) that has expressed their gratitude of your posting.
  #877 (permalink)
Old 03-20-2017, 10:49 PM
WackyRacer, Thanks for the link to the file and sharing it.
  #878 (permalink)
Old 03-21-2017, 12:50 AM
n3617400's Avatar
hi everyone.
i'm convert the ws1080 cpu firmware 4.6 from new obfuscate form (524292 bytes) to old obfuscate form (368340 bytes).
https://www.filemail.com/d/nwyhwmtlufwpkci
can anybody check this firmware? i dont have pro-668. thanx.
  #879 (permalink)
Old 03-21-2017, 1:05 AM
Originally Posted by n3617400 View Post
hi everyone.
I tried it with grefwtool 0.2.0.3 and it errors out with *transcode not supported on this scanner or version of firmware"
  #880 (permalink)
Old 03-21-2017, 1:19 AM
n3617400's Avatar
i think this problem can solve Eric only.
