I have a PRO668 and PSR-800, both with the updated firmware loaded in them. I like the new features with the updates but have seen different strategies on how to set it up to monitor multiple sites. I like how I can lock out sites on the system, however, it's is my understanding the scanner will lock on the strongest site based on settings rather than scanning a couple of sites at one time. I'm trying to monitor the Harris County Texas TxWARN system and most of the talk groups are easily heard on the Northwest Simulcast site. However, if I want to monitor Waller County as well, which is just to the west of me, there are usually no units affiliated with a NW simulcast site, and only affiliated with the site in Hempstead. I have no problems hearing those units monitoring the Hempstead site, but can't do both.
I read where duplicating the system would be a way to do it or duplicating the system and making it a one site system with a dummy site so you can adjust levels etc. When duplicating a system, I'm guessing one needs to rename it to make it easier when working with scan lists. Also, when creating scan lists, one can have one set of talk groups affiliated with one system and then the same set repeated, but affiliated with a second (the duplicated) system. I tried it that way, but it did not seem to like them being in the same scan list. Once I removed the group affiliated with the original system, and left it with only the ones affiliated the duplicated system, it seemed to work fine. If I had it scan the scan list with two systems in it, it did not seem to like it at all and did not receive either system at all.
If there was an option to make it scan certain sites on a system or just look for the strongest site, that would be great. Any tips or suggestions on how to best set duplicate systems up? It seems like there are several strategies. It would be nice if I could just duplicate the entire system and scan lists. Then I could have one system where roaming several sites and the strongest site would always be monitored and the duplicate system set up to monitor one specific site. Is that something easily done? And would that work before I start on it to find it does not work. I really like these scanners, but sometimes their Uniden counterparts (396XT and 996P2) have an advantage in some areas like this.
