Old 06-18-2017, 3:18 PM
Para078's Avatar
Question Pro 2006 Display
Just replaced the electroluminescent panel on my 2006 and still no light. I resoldered the leads but still no light. What do I do next?
Old 06-18-2017, 3:49 PM
bob550's Avatar
Several questions: Was there any degree of light with the old panel? Did you make sure to install the new panel with the correct side facing out? Do you have the 2006 with the on/off switch? Is the new panel a direct fit, or did it need to be cut? It's also possible that the inverter has failed. I replaced my EL panel maybe 3 years ago, and the replacement does not provide a level of brightness that it should.
Old 06-18-2017, 6:48 PM
PRO-2006 Service Manual
Old 06-18-2017, 9:34 PM
Para078's Avatar
It had a faint light. Mine has the dimmer switch. No change using it. The numbers still display, just can.t see 'em.
Old 06-19-2017, 1:19 PM
i have a 2005 i cant see
i dont want to spend a cent on the thing as wow it will take a eternity to program all the crap in it i want
25-1300mhz all by hand ugggg
Old 06-19-2017, 3:11 PM
LesWurk's Avatar
few years ago a progamming interface for scanners if you like to build and can find the parts.
MainPage
In any case if you don't change programming often it would be worth it to brighten the display and manually program it
Old 06-19-2017, 6:24 PM
hey thats cool
bookmarked
Originally Posted by LesWurk View Post
few years ago a progamming interface for scanners if you like to build and can find the parts.MainPage In any case if you don't change programming often it would be worth it to brighten the display and manually program it
