  #81 (permalink)
Old 08-06-2017, 10:21 AM
Hamradiostuffing's Avatar
Originally Posted by ChibiPaw View Post
I've been meaning to write an update Friday about this, but things just got busy.
Spoke to a Whistler tech, regarding to the circuit board swap upgrade for locked units.
The guy said they've ran out of boards, and is expected to resupply. May take another two to three weeks.
Joy.
It sounds like the boards are coming from the factory.
  #82 (permalink)
Old 08-11-2017, 4:31 PM
ChibiPaw's Avatar
Just got back today the one scanner had that needed the circuit board replaced.
Attached images of what you'd might expect.
I haven't picked up any DMR signal yet, since I've only got Southwest Air by the airport programmed in, and will need to drive there to verify that functionality.
  #83 (permalink)
Old 08-12-2017, 9:33 AM
Default Pre Update Pro668
OK, after I restored the radio to a PRO668, my scanner bootup comes up like the pictures below. How can I get it to not show the whistler name during boot? Thanks for the help!
  #84 (permalink)
Old 08-12-2017, 9:37 AM
mule1075's Avatar
Change it in the Iscan software.
Sent from my SM-S907VL using Tapatalk
Uniden 125at/250d/9000xlt/780xlt/796d/996t/346xt/2x396xt/996xt/HP-1E/436HP
Radio Shack Pro-2006/160/197/18.AOR 8200MK3
  #85 (permalink)
Old 08-12-2017, 10:07 AM
OK, can you help me understand how that works exactly? Is there some text that needs changing, and if so, to what? Seems to me when I reverted to the RS CPU version, it would have put that in itself. Thanks for your input.
  #86 (permalink)
Old 08-12-2017, 10:12 AM
KevinC's Avatar
Moderator---not censor
Change the "Welcome Text". It's on the "General Settings" tab, upper left corner.
Someone told me signatures are silly, so I got rid of mine.
  #87 (permalink)
Old 08-12-2017, 10:15 AM
mule1075's Avatar
Upper left corner Welcome Text in the general settings tab.
  #88 (permalink)
Old 08-12-2017, 10:16 AM
mule1075's Avatar
Edited post Kevin C beat me to the answer.
  #89 (permalink)
ChibiPaw's Avatar
Alright finally tested everything.
So the unit came back as CPU 4.8, DSP 3.0, date set to 2005.
Following the instruction, I have used their EZ Scan software to upgrade the DPS to 3.1, and current date.
After rebooting the unit, it does indeed still pick DMR signals.
  #90 (permalink)
Old 08-12-2017, 10:59 AM
OK, am in the window, now what should I change it to? Don't want anything related to whistler there before I send it in. Thanks for your help!
What should actually be on each line? Thanks!
  #91 (permalink)
Old 08-12-2017, 11:04 AM
mule1075's Avatar
Really what ever you want.i would not worry about it.I am not at home to look at the default welcome text.
  #92 (permalink)
Old 08-12-2017, 11:06 AM
Thanks, after changing the lines, do I just 'copy configuration to scanner memory SD card'?
Come on folks, I really don't want to screw up the rest of the settings I have. How do I load the 'general welcome text' screen to the scanner?
Got it! The card was partially corrupted so I copied the config to comp, formatted, then copied back with the updated text. All is good now! Thanks for the push in the right direction!
  #93 (permalink)
Old 08-12-2017, 12:12 PM
trp2525's Avatar
The default 5-line Welcome Text for the PRO-668 is as follows (with each text item centered on each line):
radioshack
PRO-668
iScan DG
Digital
Trunking Scanner
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, PRO-668 (officially upgraded to WS1080), TRX-2, BC950XLT, BCD996XT, BCD396XT, Motorola Minitor II, Antenna Specialists MON731
  #94 (permalink)
Old 08-13-2017, 9:23 AM
radioshack
PRO-668
iScan DG
Digital
Trunking Scanner
Hey thanks! I had gotten it earlier, good to see the right info for the screen at boot now.
