Old 08-12-2017, 7:28 PM
Default pro652
I have a radio shack pro652 when turned on display says OBJECT ORIINTATED DIGITAL TRUNKING PSR500 it scans channels but no sound
Old 08-12-2017, 8:26 PM
KevinC's Avatar
Moderator---not censor
Moved to the Radio Shack forum.
Someone told me signatures are silly, so I got rid of mine.
Old 08-12-2017, 9:48 PM
It sounds like it needs to be flashed/programmed with a version of the PRO-652 software. I don't believe it should say anything about the PSR500 version on the display when booting. Possibly someone tried to update the software for this scanner with a file intended for the PSR500?
I have a copy of the CPU updater for the PRO-651 which should be the same as for the PRO-652. If you would like a copy just send me your e-mail by private message.
You could also try plugging in a pair of headsets into the headphone jack to see if those work. It could be a dirty or defective headphone jack causing the problem.
Shawn
Old 08-12-2017, 10:25 PM
Chronic's Avatar
the PSR 500 text is / can be programed when the scanner is programed with software , I know in arc 500 you can make that boot up text say anything you want . I have mine set to say property of and my name and callsign .
Old 08-13-2017, 12:11 AM
trp2525's Avatar
Try downloading and installing the latest version 2.9 firmware for the PRO-651/PRO-652. You can get the direct download link for the firmware from my Radio Reference posting located here: http://forums.radioreference.com/rad...ml#post2583244
trp2525
RCA 16S400, Regency HX1500, PRO-2006, PRO-197, PRO-668 (officially upgraded to WS1080), TRX-2, BC950XLT, BCD996XT, BCD396XT, Motorola Minitor II, Antenna Specialists MON731
