Originally Posted by tatertot1
Thanks for the reply Dave...I tried that. I dont see anything change on the display...just the flat green line. I'm stumped!! Oh yea, and aggrivated too!!!!! lol
Make sure that you are using the same input that your scanner is plugged into. If it is plugged into the mike jack, do the following:
- Double click the little speaker in the task tray near the clock.
- Pull down "Options", and select "Properties".
- Click the circle next to "Recording", and select "OK".
- Make sure that the box under "Mic" is checked.
If your scanner is plugged into the "Line In" jack, make sure that the box under "Line" is checked instead of mic. While you will hear all the devices that are not muted under the "Playback" properties, it is the "Recording" properties that will dictate which input the computer will use.
Dewey
