Old 01-29-2018, 8:35 PM
Question PRO 93
Anyone knows how to connect a PRO 93 to Windows 10?
Old 01-29-2018, 8:44 PM
doctordialtone's Avatar
Post PRO 93
Start here:
Easier to Read Pro-93/95/2053 Scanner Manual
Have the cable?
~Doc
Old 01-30-2018, 2:19 PM
gmclam's Avatar
Smile PRO-93
You need the correct serial cable and its driver for WIN10.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 01-30-2018, 6:39 PM
Question
Where would I download the driver?
Old 01-31-2018, 10:27 AM
Wiki Admin Emeritus
Therein lies a bit of a rub - you might be able to find the RS USB cable (original SKUs were 20-047 or 20-546) on Amazon or eBay, and they may have the drivers on their website. If not, we have the FTDI drivers in the Aftermarket section of...
Connecting scanners via USB - The RadioReference Wiki
I'm not familiar with these aftermarket suppliers, so caveat emptor. If there are better suppliers of the RS USB cable, then let's have it.
Be sure to get the right version of the drivers - Windoze has gotten picky about issues with unsigned drivers and the like. Drivers for Win 8.x will also likely work with Win10
GL...Mike
co-author, HF Digital Decoding
Old 01-31-2018, 10:45 AM
Whistler still sells the cable that was used with the Pro 96 and Pro 106. It should also work with your radio. Do a Google for Pro 93 usb cable.
Old 02-27-2018, 10:42 AM
johnnyelectron's Avatar
PM me about a PRO-96, PRO-92 programming unit from RS.
