Old 06-14-2018, 10:17 AM
Bubba1661's Avatar
WV DB Admin
Default PL Tones
A local business that I am trying to pick up has a PL tone of 103.8, that was programmed by their radio provider, Is there a way to manually put it it a Pro-651? I have tried everything.
Bubba1661
West Virginia Scanner's Group
Old 06-14-2018, 10:38 AM
103.5 should work. I know of no PL decoder that is THAT picky.
And tell them to get a radio provider that knows what they are doing.
Old 06-14-2018, 1:07 PM
You have probably already tried 103.5 without success so it is most probably another PL tone being used. Could it be 173.8 ?
Go into the West Virginia forum and state the company and frequency and somebody there could then probably give you the correct PL tone.
/Ubbe
Old 06-14-2018, 2:02 PM
And just a reminder you don't need a PL tone to monitor a frequency. You would only need PL if you are trying to identify different users on the same frequency.
BB
Old 06-14-2018, 5:08 PM
Bubba1661's Avatar
WV DB Admin
Actually the Radio Tech told me directly that they programmed those PLs like that on purpose. So I will try to monitor the frequency without a tone and see what happens. Thanks for all the advice!
Bubba1661
Old 06-14-2018, 6:21 PM
The difference are 0.3% and standard spec for professional radios are that a CTCSS/PL decoder must not be narrower than 0.5% and max 3% so I do not think that those 3 tenths of a Hertz makes any difference to a scanner. I beleive my AR8200 sometimes even decodes the neigbour CTCSS tones.
Your problem lies somewhere else.
/Ubbe
