I'm having a problem with the lockout. i will lockout some channels turn the radio off and on again the channels that were locked out are now available to listen to.
There are 2 lockout levels. One is the temporary lockout which works as you've described.
The other is a permanent lockout. Press Func, then Lockout, and the object will stay locked out until you unlock it again.
