Old 12-05-2018, 5:01 PM
Default Spanning Bands
I have a Radio Shack pro 83. I have it programed in 4 bands. I need to start with band 1 and go to 2, 3, and 4 then back to 1 again. Is there a way to do this?
Old 12-05-2018, 5:33 PM
KE5BCP's Avatar
Do you mean "Banks" instead of "Bands"?
If so, turn off the other banks and it will scan 1, 2, 3, 4, and repeat.
Old 12-05-2018, 5:38 PM
KE5BCP you were correct, I did mean bands. I have the other bands turned off but I don't think it is going past channel 10.
Old 12-06-2018, 4:30 PM
download the manual page 48 shows how to switch banks on and off bank number flashes as its scanned. https://www.manualslib.com/manual/13...ck-Pro-83.html
Old 12-06-2018, 5:01 PM
garysvan,
Thanks for the reply. The only bands that I have showing are 1,2,3,and 4. The rest are turned off but band 1 is the only one flashing. That is why I don't think 2, 3, and 4 are scanning. I don't hear anything that is on those bands.
Old 12-06-2018, 5:32 PM
sounds like you do not have anything programed into the other banks press hold and then enter a channel number in the other banks like channel 21 then press hold again it will show what is programed into it.
Old 12-06-2018, 6:09 PM
I tried that and there was nothing. I can't figure that out. I used the software and programmed it yesterday.
Old 12-06-2018, 6:33 PM
there is a learning curve on programing scanners you will have to try programing it again i have gotten frustrated enough i had to put a few scanners down and try again another day
