Old 01-03-2007, 12:44 AM
Smile Question about a Pro-97 1,000 Channel Triple Trunking:
First I'd like to say Happy New Years to all you happy scanner owners! My husband bought me a Pro-97, i'm wondering if I'm going to need an antanna of some kind other then the one on me Pro-97 ? I live two miles outside of town and don't seem to be picking much up, when I'm talking to my nephew in the same town, his is going non-stop! I have squelching noises off and on when someone is to make a reply to an officer, rather then a vioce. I turned the squelch off but still incounter this noise from time to time. I wish they had a trouble shooting page in the owners manual, but there was none. Thanks alot guys for any help!
Old 01-03-2007, 12:58 AM
GreatLakes's Avatar
Not Posting
Happy New Year to you also!
Two miles should not present a problem, even with the stock antenna. Do you have the same frequencies programmed as your nephew has? Is he using the same radio. Can you tell us what County/City/State you're located in?
Thanks!
Old 01-03-2007, 9:17 AM
scanny_man's Avatar
I'm her nephew and i have a BC92xlt and yes mine goes constantly.
Old 01-03-2007, 9:39 AM
GreatLakes's Avatar
Not Posting
Does she have the exact same frequencies programmed? Did you program it, or did she? Also make sure the squelch is adjusted properly, and that the programmed bank(s) are enabled.
Can you clarify this: "I have squelching noises off and on when someone is to make a reply to an officer, rather then a vioce." ?
Old 01-03-2007, 10:36 AM
Default Question About a Pro-97 1,000 Chanel Triple Trunking:
Can you clarify this: "I have squelching noises off and on when someone is to make a reply to an officer, rather then a vioce" ?
Sorry about that! I meant to spell voice instead of vioce. When someone responds to the dispatcher instead of a voice I get a squelching sound. This can be annoying when my volume is up high.
Old 01-03-2007, 10:41 AM
Thanks!
Thanks for the reply! I think I will get together with my nephew today and see which fregencies he has programed in his, but basically I'm thinking they are about the same. His Scanner on the other hand is a different brand then mine. I live in Sedalia, Mo which is in Pettis County.
Old 01-03-2007, 11:21 AM
GreatLakes's Avatar
Not Posting
I'm sorry, I wasn't criticizing your spelling, I just didn't understand exactly what you were hearing. Did you mean the squelch opened up, and you heard the usual background static type noise, or something different? Some radio systems (ie; trunking, digital, etc), make irritating noises when they're transmitting data.
Old 01-03-2007, 11:30 AM
GreatLakes's Avatar
Not Posting
Here is a link on the Radio Reference Database listing frequencies for your area:
http://radioreference.com/modules.php?name=RR&ctid=1558
I think you are telling me you didn't program it at all? If you're just trying to use the preprogrammed frequencies that came in the scanner, that is the problem.
Hope this helps!
Old 01-03-2007, 12:10 PM
scanny_man's Avatar
yes i am programming her scanner and every once and awhile there are outbursts of a fax machine sound..even on mine and i'm not sure what that is..it sounds like a fax machine going off
Old 01-03-2007, 12:32 PM
kicktd's Avatar
what frequency is it? is it a trunked group? That almost sounds like it could either be a Control Channel sneaking in OR it could be possible they are using encryption when transmitting?
RTL-SDR running sdrtrunk
Old 01-03-2007, 12:51 PM
scanny_man's Avatar
well the frequency is 451.1500...not sure if its trunked or whatever cuz i don't know much about that...but i usually pick up my neighbors and Aquila on it but every 2 or 3 minutes have to hear that sound....
Old 01-03-2007, 1:05 PM
Dubbin's Avatar
That is from a LTR trunking system http://radioreference.com/modules.php?name=RR&sid=4631
Dwayne
My Scanner Feed
Old 01-03-2007, 1:20 PM
scanny_man's Avatar
ok so it is trunked
Old 01-03-2007, 1:32 PM
Just wanted to let everyone know, that I just got home from scanny-man's house, and my scanner is wrking much better now. I think he programed more channels in it.
Old 01-04-2007, 4:52 PM
I think you are right, I think it's just my type of radio system, as to why I'm having the static noise. I had the squelch turned down. My nephew { scanner-man} programed more channels into my scanner and it works much better now.
Old 01-04-2007, 6:16 PM
Almost sounds like a "paging system" that is close by and bleeding over onto some of the frequencies.
PRO-197
PRO-164
