Old 04-09-2007, 9:48 PM
Default Very Amateur Question
I am trying to learn "trunking". I need to select an option of Motorola type I, Motorola type II, etc.
In the database it is labeled as apco-25. The database also says it is Type: RM. I'm not too sure if I am capable of listening in on this trunck or not.
I have a Pro-528.
Thanks for any help,
Turk
Old 04-10-2007, 1:39 AM
NeFire242's Avatar
You can learn more about trunking on the Wiki here:
http://wiki.radioreference.com/index.php/Motorola
"R" means Repeater.
"M" means Mobile Radio.
I have a Pro-528.
I do not believe the Pro528 will do digital such as APCO (P25), it's an analog only scanner.
