Old 10-03-2007, 7:20 PM
N8DV's Avatar
Default Who manufactures Radio Shack scanners?
With all the discussion of RS scanners and that GRE is no longer manufacturing for RS, who is making RS scanners? Does anyone have an idea?
Old 10-03-2007, 7:26 PM
madnachos's Avatar
GRE and Uniden.
Uniden BCT15 / BR330T / Pro-96 / Pro-97 / Pro-95 / Pro-2051 / Kaito KA2100
Old 10-03-2007, 7:30 PM
n2mdk's Avatar
If the association with GRE is over that leaves only Uniden.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 10-03-2007, 7:39 PM
madnachos's Avatar
Everything RS has on shelf now was made by GRE or Uniden. Yes, GRE wont be making scanners anymore for RS (I guess) but most current models were made by GRE.
Old 10-04-2007, 8:15 AM
DickH's Avatar
There are actually two Unidens. Uniden, USA and Uniden, Japan. The PRO-433 and PRO-528 are Uniden, Japan products and Uniden, USA denies any knowledge of them.
Dick H
http://dickh.zenfolio.com
Old 10-04-2007, 8:51 AM
spiritwolfpr's Avatar
Send a message via AIM to spiritwolfpr
Hello Friends:
Then who made the PRO-60 GRE or Uniden??
with Blessings,
Rafael
The spiritwolfpr
KF4-LED
Old 10-04-2007, 9:08 AM
hoser147's Avatar
Smile
Spiritwolf, GRE Made your Pro 60 here is the link from Strong Signals. Hoser http://www.strongsignals.net/access/...s=recv&num=005
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 10-04-2007, 9:19 AM
Hello Friends.
Thanks Hoser147 , dude
with Blessings,
Rafael
The spiritwolfpr
KF4-LED
Old 10-04-2007, 12:22 PM
Silent Key
Who from GRE has said they will no longer make scanners for RS? Just because the new models that are coming out will not be limited by sale to RS, they still have manfufacturing facilities and if they have spare time it would only make sense to make scanners for RS or anyone else. This is why Uniden makes scanners for RS.
I have never found that criticism is ever inhibited by ignorance
Old 10-04-2007, 1:12 PM
N8DV's Avatar
This poses an interesting situation: if Uniden makes RS scanners, what not just buy Uniden instead of RS. I hope the quality is the same. Same with GRE, just buy GRE instead of RS. I assume, that when RS has either Uniden or GRE make their scanners, the quality is as good as the named brands. Am I wrong or assuming too much?
Old 10-04-2007, 2:04 PM
n2mdk's Avatar
Up until now GRE didn't market their radios in the US except through RS, some of the Uniden made radios were custom made for RS and as someone else said some were designed not by Uniden US.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 10-04-2007, 4:54 PM
UPMan's Avatar
RS scanners made by either mfr are spec'd by RS as to how they will operate (i.e. all RS to date use "banked" memory, include "SKYWARN" as a feature button, etc). Hardware-wise the quality should be comparable, but the feature sets and implementation will differ.
Uniden Product Ninja
Professional Scanner Developer
Old 10-04-2007, 5:14 PM
DaveIN's Avatar
I find it interesting that the new Uniden OEM PRO-162 has an "open and close" mode for the bank, as mentioned in the pre-release FCC TA Owners Manual. This is a different feature from the norm found on other Uniden OEM radios.
