How dose one get the PRO-2096 open and install a discriminator? Thank You
T TexScan780D Member Premium Subscriber Joined Feb 20, 2003 Messages 1,162 Nov 18, 2007 #1 How dose one get the PRO-2096 open and install a discriminator? Thank You
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Nov 18, 2007 #2 Honestly, if you don't even know how to open it then I would recommend you have someone install the tap for you.
T TexScan780D Member Premium Subscriber Joined Feb 20, 2003 Messages 1,162 Nov 19, 2007 #3 Dubbin said: Honestly, if you don't even know how to open it then I would recommend you have someone install the tap for you. Click to expand... I have removed the black cover (outer cover) and taken out the 8 side screws of the inner housing, but there is something preventing the unit from sliding out of the inner housing.
kc9cau Member Joined Dec 19, 2002 Messages 7 Location south bend indiana usa Nov 30, 2009 #4 the inner case it in 2 pieces and lifts off note the side with the speaker use caution when removing the speaker wire from the board
T TexScan780D Member Premium Subscriber Joined Feb 20, 2003 Messages 1,162 Nov 30, 2009 #5 kc9cau said: the inner case it in 2 pieces and lifts off note the side with the speaker use caution when removing the speaker wire from the board Click to expand... Thanks for the reply. Did you install a discriminator tap?
S saintpaulfirefighter Member Joined Mar 5, 2008 Messages 34 Location minnesota Nov 30, 2009 #6 stupid question here..what is a discriminator tap and what does it do
qlajlu Silent Key Joined Jul 25, 2005 Messages 2,286 Location Kearns, Utah Nov 30, 2009 #7 saintpaulfirefighter said: stupid question here..what is a discriminator tap and what does it do Click to expand... In this case, the Wiki is your friend. You will find a discussion here. No questions are stupid. If you didn't ask, someone else would.
