Old 01-04-2008, 02:33 PM
Default Pro-97 Trunking
Hello, I am completely new to the entire radio scene, but one of my friends has asked me to program his Pro-97 for him. Unfortunately I can't figure any of it out! Please, I need to add these channels to a Pro-97:
13808
13680
13712
Could you please write a quick how-to for me? I need it as soon as possible!
Old 01-04-2008, 02:37 PM
W5JSS's Avatar
13808
13680
13712
Those are talkgroups of a trunked system.
See this guide: http://wiki.radioreference.com/index...hortcut_Pro-97
Old 01-04-2008, 03:30 PM
now that I have them entered how do I listen to them ?
Old 01-04-2008, 04:25 PM
n2mdk's Avatar
If the trunked frequencies and the TGIDs are programmed in correctly simply hit scan.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 01-04-2008, 04:36 PM
what's the TGID?
Old 01-04-2008, 04:37 PM
n2mdk's Avatar
what's the TGID?
Talkgroup TG ID ID= TGID
13808
13680
13712
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 01-06-2008, 10:23 AM
so would the TGIDs be the same as the trunked frequencies?
Old 01-06-2008, 10:28 AM
Dubbin's Avatar
No, you will need to enter the trunked system freq then add the TG's.
Dwayne
My Scanner Feed
Old 01-06-2008, 03:26 PM
Eh, I'm sorry, I really don't quite get what you're saying..
I have the TGIDs, and I need some other frequencies?
Try to walk me through it
Old 01-06-2008, 03:55 PM
n2mdk's Avatar
We need more info, like Country, State, County, and City/Locality. Then we can help you more.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 01-06-2008, 05:54 PM
br0adband's Avatar
Send a message via Yahoo to br0adband
Trunked systems work like this:
You have the system itself. Inside the system you have frequencies that the system is allowed to use; it could be 5 frequencies, 7, 10, 15, even 20 depending on the capacity as well as the needs of the system when it's designed, but future expansion is always a possibility.
One, two, or three of those frequencies (again, depending on the size and capacity) are assigned as control channels - you need to understand the fundamental difference here between frequency and channel. Frequency would mean the actual radio frequency being put to use for that purpose; channel would mean the assigned purpose.
To break that concept down, the FCC will license you 10 frequencies, but they could care less what you use the first frequency for, or the second, or the third basically. You come in and say "Ok, let's use this frequency as channel 1, this as channel 2, etc. See the difference there? I hope so...
Ok, a control channel in a trunked system is specifically assigned to do one thing: broadcast the control channel data from the radio system itself to all the radios that are "listening" and part of the system. An analogy would be this:
The human Dispatcher in a system is in charge of assigning jobs, tasks, priorities, needs, etc. That makes sense, right? The Dispatcher calls out and says "Unit XX, go do this" or "Unit YY, switch to channel 4 for further information" etc.
The control channel does the same thing, but instead of telling the actual people on the radio system what to do, what channel to be on, or defining which radio they're assigned, it's sending those instructions directly to the radios themselves. It's an electronic Dispatcher, somewhat, and the "units" are each and every single radio that's part of that trunked system.
Each and every radio in that system technically has two tuners in it: one is always listening to the control channel frequency - the one assigned for control channel broadcast purposes (I mentioned the 1, 2, 3, or even more that can be used in systems but typically only 1 control channel is broadcasting at any given time). The other tuner/transceiver is used for the actual voice traffic when the radio owner presses transmit to talk to someone on the system, or when they're listening to activity from Dispatch (the human Dispatcher) or other units in the field, etc.
Ok, because of how a trunked system works, it allows for a great number of actual radio communications to happen at any given time. In the old days, you'd have a system with 3, maybe 4 frequencies in a small town/community. The police might use one of those, the fire dept might use another, local government a third, and the fourth could be used for emergencies. Now consider that in such a situation, only 1 radio communication would happen on each frequency at any given time. In a high stress situation, imagine that if the police frequency was busy with some information traffic (someone running a license plate and needing to transmit all the VIN letters one at a time) and in the middle of that another officer gets in an accident or, heaven forbid, gets shot or something worse.
That officer can't transmit because the frequency is in use, right? Right, it's a bad way of doing things. Then someone came up with the idea of trunked communications. That basically works by having a set of frequencies as I explained above (5, 7, 10, 15, 20 or more) and the radios are designed to "hop" frequencies as needed - they don't remain on a static frequency. In some respects, a lot of trunked radio system technology is borrowed from cellular technology, but proximity to cell towers and signal strength (which is how cell phones "hop" cell sites) don't relate here; trunked systems "hop" frequencies because the control channel tells them to, and which frequency to hop to.
On top of all of this, the additional benefit is that each radio can have a unique digital ID, commonly called an RID (radio ID, go figure). Because of this, you can group radio IDs together into <drumroll please> talkgroups and each talkgroup can be assigned an ID also. Those TGIDs or TGs for short (talkgroup IDs or talkgroups) are what you were talking about in the OP (original post) above. The 5 digit decimal codes you posted:
13808
13680
13712
are TGIDs for the trunked system you happen to be monitoring. Unfortunately, you neglected to provide us with any more information so, we can't help you identify the TGIDs because we don't know what system you're monitoring, what location or part of the world you're in, the city, state, etc. That info can lead to finding out what those TGIDs are actually assigned for based on the city/state information you can provide and then use to look up the info (probably) in the RadioReference database here at this website/forum.
The beauty of talkgroups is that you can assign a radio to be in that group and then that group communicates with itself: say you wanted a bunch of officers assigned to the southeastern part of the city, you can create a talkgroup for just them and assign it a talkgroup ID of 13808 (I'm just using your first TGID as an example here, bear that in mind) and then label it "Southeast Patrol." Now, when anyone that's in that talkgroup transmits, the only people on the entire trunked radio system that will be able to hear that person talking/transmitting are those with their radios set for the same talkgroup - understand?
When they press the Transmit button, all of this happens in a fraction of a second:
1 - The radio transmits the radio ID and the talkgroup ID to the Dispatch computer
2 - The Dispatch computer checks to make sure the radio is actually part of the system
3 - The Dispatch computer checks for the next open frequency to command all the radios in the same talkgroup to "hop" to so they can monitor what your radio is about to transmit
4 - The Dispatch computer sends out the command (using the control channel) for all radios in the 13808 talkgroup to "hop" to frequency XXX.XXXX and open their squelch so they can listen to the broadcast from your radio
5 - The Dispatch computer sends an OK signal to your radio to begin transmitting its audio signal and then all the others in the talkgroup hear it.
Those 5 basic steps happen every single time someone presses Transmit on a trunked radio system radio. The "OK" signal to transmit is audible on many systems: you can spot it whenever someone keys a mic (presses Transmit) as the "beepbeepbeepbeep" - 4 quick beeps in rapid succession that are usually heard within about 1 second of the person actually pushing the Transmit button. That's their audible signal from the radio that means "Ok, I just talked with the Dispatch computer and all the other units are now listening, go ahead and talk." Not all systems use it, of course, but a great many do.
A trunked system allows far more people to use a radio system in a vastly more efficient way. In Las Vegas where I live, there's one system here that I monitor constantly that's primarily run by the county itself (Clark County) and there are over 5000 radios on the system, and over 380 talkgroups. That kind of system simply wouldn't be possible on the old 4 frequency/channel "small town" style hardware anymore.
Now, with the trunked system in place, the police depts here all have their own talkgroups, the fire does, the airport here (one of the busiest in the nation) has theirs, local govt, county govt, community service, the jails, detention center, etc - they all use the same radio hardware, just different talkgroups. This has the added benefit that if something major happens, there's no issue with a bunch of different radio systems that can't communicate with each other. Any given unit can be programmed (if it's not already) to switch talkgroups from one purpose to another in an emergency situation, so the cost savings is enormous too.
I've rambled on long enough... if you provide us your city/state, we can probably find out what those talkgroups actually are.
Good luck...
The difference between genius and stupidity?
Genius has limits.
Old 01-06-2008, 06:52 PM
sfleuriet's Avatar
Holy mother. I would love to read that post, but I'd like to be in bed by midnight. Lol
Edit: Great info.. that really helped me understand some more
-Pro-97-
Old 01-06-2008, 06:58 PM
sfleuriet's Avatar
Is that in place for EVERY trunked system, or just certain ones that are set up in that manner? Also, that system of steps doesn't exist in a conventional system does it?
-Pro-97-
Old 01-06-2008, 07:03 PM
br0adband's Avatar
Well, one other benefit of trunked systems and digital communications (and I don't mean a digitally trunked system by that as in APCO P25 stuff; I mean a system using digital communications for the control/radio ID purposes, hope that difference is clear) is that each radio needs to be recognized by the system. Because each one has a unique digital radio ID that gets transmitted every time the Transmit button is pressed, it gives a fairly "secure" sense to the whole system.
It's entirely possible for a Dispatcher to cause a specific radio to reset, turn on, turn off, stop transmitting, open squelch, sound an alert tone, etc... all this sort of operation is possible remotely from the Dispatch console with the right commands.
The other added benefit is that if a radio is stolen - rare but it happens - the Dispatch console can send out a terminate signal and that radio will basically get bricked dead, useless for most if not all intents and purposes. Of course, there are people with the knowledge to restore them to functional operation, but overall if such a radio is bricked with a terminate signal, it's toast.
Hope that helps...
Genius has limits.
Old 01-06-2008, 07:58 PM
n2mdk's Avatar
I'm going to sort of simplify things down, think of a trunked radio system as a wireless network, each radio is assigned a sort of address to use and each radio needs a network key to operate off the system. As a matter of fact unauthorized use of a trunked system is considered as hacking into a computer network.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 01-07-2008, 12:47 PM
thanks for the info, both to br0adband and n2mdk..
Kay, so you need more info.
The area I am in is US, Texas, Pearland/Brazoria County.
Old 01-07-2008, 12:56 PM
n2mdk's Avatar
The info you need is in this data base http://www.radioreference.com/apps/db/?sid=38
The system seems to be mixed and doesn't say which might be digital, hopefully it isn't all digital.
Look down at site 013 Brazoria then down the talkgroup list for it as well.
There are also some conventional frequencies listed here as well http://www.radioreference.com/apps/db/?ctid=2542
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Old 01-07-2008, 05:38 PM
ok so what do I do with that information?
Old 01-07-2008, 05:57 PM
sfleuriet's Avatar
I can tell you from experience, it's MUCH easier (and friendly to support this website) to purchase the Premium Subscription to directly import information into Win97.
http://www.radioreference.com/apps/subscription/
-Pro-97-
Old 01-07-2008, 06:03 PM
Highpockets's Avatar
Your learning pretty quick!
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Similar Threads
Unable to load Pro 97 with Win 97 file shajoe44 Radio Shack Scanners 14 07-12-2007 02:36 PM
FS/ Pro 2051 Base/Mobile Trunking Scanner 1000 Channels Wilf11 Old Classifieds Archives 2 07-05-2007 12:15 AM
Pro 97 belt clip Dougr Radio Shack Scanners 11 03-31-2007 04:39 PM
FS: Pro 97 Pro 83 and Pro 2050 benjaminarthurt Old Classifieds Archives 3 03-14-2007 08:20 PM
clone from pro 95 to pro 97 ? derekjmu Radio Shack Scanners 5 02-03-2007 11:48 PM
