Originally Posted by icom1020
I thought I read a thread on the 2055 group that trimming was only temporary, all it does is shorten the cable. The issue turned out to be the molex connector. Some had success in removing the cable,opening the connector and inserting something like cardstock--closing against then remove cardstock, then opening the connector and re inserting the cable and close connector. Any one else do this or just replace the connector?
Quite honestly, once I got to the right ribbon, (I'm such a tool!) all I did was clean the ribbon, and re-insert it. Same with the PRO-97. It seems to be working. Let's see what happens.
