| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
03-07-2008, 08:24 PM
Pro 97 vs Pro 164 vs PSR 300
I did have a Pro 97 that was awesome however this evening came home from work and fell asleep to hear a loud crash. I awoke to find my wife had left the office door unlocked and my little boy had got in there and took my Pro 97 and was running from my wife as she was asking for the radio back and threw the radio on our tile floor. So now I have a broken Pro 97 will not power up took it apart attempted to fix it however its in multiple pieces internally as well. I was pretty upset have other radios however even though the Pro 97 is not re-band complaint its one of my favorite radios to listen to conventional stuff. I now want to replace the radio with either another Pro 97, a Pro 164 or a PSR 300. My wife was pretty upset and she told me that I could replace the radio. So my question is what is the best way to go? Any links to threads comparing the models? Any recommendations would be greatly appreciated.
Fireant
03-07-2008, 09:13 PM
I've only had a PRO-164 for a few days, but so far I like it. I was leaning toward the PSR-300, but liked the idea of just heading over to RS to pick up the scanner as opposed to ordering one in. I almost bought a PRO-97, as RS had them in stock locally and they were down to $150, but then for $220 I got something that can handle rebanding.
My understanding is the PRO-164 essentially is a PSR-300, just with some cosmetic changes.
The only major complaint I have is the manual is almost worthless - but that applies to the PSR-300 manual as well, I downloaded it and it's almost an exact copy of the RS one. (Or vice versa.) I'm still not entirely sure how to work all the features of this thing, or even what all the stuff on the screen means, but I'm getting there.
Software programming is almost a requirement, in my opinion. Win97 does that very nicely.
I almost bought another PRO-97, as RS had them in stock locally and they were down to $150, but then for $220 I got something that can handle rebanding.
DB Admin Member
Well for me its a no brainier you have owned a pro-97 the pro-164 and psr-300 are made by GRE, they are just about the same scanner and you can use WIN 97 with both what ever one cost less and I could get my hands on 1ST would be the one that I would get both the 164 and 300 can get freqs that the 97 cannot. so why get something that will not survive rebanding and when the wife tells you to replace it, get the good stuff. The 164 or I would get the 300 but like I said they are just about the same if not just the same.
03-07-2008, 09:27 PM
I would go for the PSR-300 mainly because for the fact that at the $200 price tag it includes the AC adapter. You can get one from Lentini through eBay for $199.95 shipped.
http://cgi.ebay.com/NEW-GRE-PSR-300-...QQcmdZViewItem
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
03-07-2008, 09:29 PM
Ah, good point - I didn't think about that. Fortunately, I had some spare 9V wall-warts already (from old scanners!) - although I do need a proper-sized plug. Still cheaper than buying the whole adapter!
So definitely a point in favor of the PSR-300.
03-07-2008, 09:36 PM
I have a Pro-97, although it's a good scanner, I wish it would brake so I could get the 164 or the 300 :P
03-07-2008, 09:42 PM
DB Admin Member
I bet they are all the same plug for the 97,164,300
03-07-2008, 09:57 PM
I can't comment on the Pro-164. I do howerver have the PSR-300. Nice to get the wall wart included with the scanner  . I owned a Pro-97 which I really liked, and I can tell You the PSR-300 can pick up comms the Pro-97 could not. I purchased it from Lentini and am very happy with thier quick service.
03-08-2008, 04:36 AM
Stick with a 97 or a PSR-300, stay away from the 164. Not too much differance between it and a 97. the Display has a few things added and it Trunks 700MHz. (Analog). GRE has been very quick to "fix" the glitches with the PSR-300, R/S is not so quick to Fix the same problems. I had a 164 and completely lost the ability to Trunk, did a reset and re-programmed the radio twice with No fix. took it back for a 97. No One here is Trunking 700MHz. in Analog so I don't miss the extended range. Win97 allows for the same 7.5KHz channel spacing on VHF so for me the PRO-97 was a better option, its a proven radio. However, I strongly suggest that if you care about your Money. Buy GRE or UNIDEN.
Just my Two-Cents
KF5CXT/WQIW237
Trenton, Texas USA
V-8000 - FT2800M - PSR600 - PRO106 - PRO160 - BC898T - IC-F221 - IC-F70D
03-10-2008, 07:19 AM
I would go with the PSR line. GRE has has stepped up and made a line of fantastic scanners. I am sick and tired of the RS BS and I know the 97 and 2055 etc are made by GRE but there nothing like having an official GRE line of equipment. I too say the 300 and 400 are far more senstive and dynamic then the 97 or 2055. GRE is staying on top of issues and has made the PSR line user and upgradable friendly. Go with PSR line, you will not be dissapointed. Happy Scanning...
P.J. Maguire KE5JVM
W5YJ OSU Amateur Radio Club http://w5yj.okstate.edu/
GRE PSR-400, Yaesu FT-250R, Icom IC-F11, Icom IC-F21
03-10-2008, 08:35 AM
Just my Two-Cents
just fyi ... the pro164 IS the psr300 with different colored buttons ... it has the EXACT same display, and the EXACT same internal workings ... my two cents
-Matt
Uniden BCT15 and BC246T . Kenwood TK-3160 and 260G . RS Pro-106
03-10-2008, 10:55 AM
can you download firmware updates from RS's website and update it as time goes by, just like the psr-300?
03-10-2008, 11:21 AM
There are some other differences the 164 can't use the 300 firmware nor can the 2 scanners clone from each other.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
03-10-2008, 11:46 AM
well that sucks ... my bad guys, i was under the impression it was purley cosmetic ... why on earth would they do something like this?
edit:
those have to be firmware only differences right? i mean, theres no way they made two different scanners (hardware wise)
-Matt
03-10-2008, 12:53 PM
Oh the 164 and the 300 are the same huh?
1-The GRE PSR 300/500 Firmware upgrade WILL NOT WORK on the 164.
2-The EPROMM is very Differant from the 300 to the 164
Case, Appearance, User manual & Cosmetics don't mean the radio has the same guts or brain. GRE has released a Firmware upgrade for the 300/400, and it specifies to NOT download it for the Pro-164. another post in a previous forum explains this. So before you tell someone the two are the same and the Firmware works on both, they download it and find it Destroyed there radio. I suggest you do some homework into the PSR-300 and R/S 164.
These are NOT the same radio what-so-ever. two seperate product lines.
Go GRE More bang for the Buck!
KF5CXT/WQIW237
Trenton, Texas USA
03-10-2008, 01:06 PM
why would anyone use the psr500 firmware with a pro164?
I assume you mean EPROM (or EEPROM) and Different
just because it says RadioShack on the front of it doesn't change the fact that GRE made the fargin thing ...
I challenge someone to prove to me that these two scanners have different insides.... it just doesn't make sense to me why one company would develope the same scanner twice ...
EDIT:
and how do you explain this?
http://tinyurl.com/38jzec
also, I cant find any posts on someone using the psr300 firmware on their pro164 ... can you post a link to it?
-Matt
03-10-2008, 02:00 PM
ok, I think I found the thread you were refering to:
http://www.radioreference.com/forums...ad.php?t=97376
Don! where are you  ..... in your experiences developing win97, would you say that there are more differences between the 300/164 than the difference in the firmware?
-Matt
03-10-2008, 06:25 PM
Based on my knowledge of the PSR-300/400 and PRO-164/163, I'd say they're exactly the same radios, with the only differences being:
* external cosmetics
* GRE and RS versions won't clone to each other
* cannot load GRE firmware to an RS radio
03-10-2008, 08:51 PM
Choices...
Go with what you can afford. The PRO-97 is on sale for $149.99, plus tax. You already had this radio. The PRO-164 is $219.99 plus tax. This radio was on sale some time ago for $179.99. The PSR-300 is $199.95, no tax, free shipping from Lentini (100% feedback rating). You just have to wait a few days to get it. IMHO I'd go with the GRE, for all the reasons stated in the previous posts. Win97 supports the radio, as well. The decision is ultimately yours. I hope we've been helpful and informative.
Eric
FDNY*EMS Captain
Citywide Dispatch Supervisor
KC2SDZ
WQKB645
03-11-2008, 07:50 AM
thanks for the input Don!
and Eric, don't forget that win97 supports all three of these scanners
-Matt
