Go Back   The RadioReference.com Forums > Topic Specific Forums > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum This is the place to discuss monitoring railroad communications.
Old 06-16-2009, 03:43 PM
Default Best attic antenna for VHF
I am listening to Railroad VHF and I am using a mag mount antenna in my attic that is working pretty good. What I wanted to know is does anyone know of any other antenna that would work even better?
Old 06-16-2009, 07:07 PM
If that mag mount isn't on some type of metal foundation, it will help if you put it on something like a steel cookie sheet. You may already have done this, of course.
Dick
WD9GRI
Milwaukee, WI
Old 06-16-2009, 08:07 PM
IrvingtonVFD43's Avatar
Send a message via AIM to IrvingtonVFD43
Another option is you can purchase a TrainTenna, manufactured by DPD Productions, it's kinda pricey, but If you have at least 4 feet of vertical space in your attic, you can't go wrong. A ground plane is not needed. I use the outdoor vertical TrainTenna to receive trains, and send them to my streaming audio site. To me, TrainTenna is unbeatable. Not to mention, DPD also produces a mag mount and an indoor model as well.
Also, any 2 meter Ham antenna, or an antenna cut to the 160-162 mhz range, mag or base will produce excellent results as well. Pay attention to the coax, using cheap coax such as RG58 on long runs will create a bit of signal loss. Go with RG8, RG6 or better.
Rich, Living 1/2 mi north of BNSF MP 24.45 Omaha Line, former BNSF Conductor, Neb. Division, and Firefighter/EMT with Irvington VFD., http://www.irvingtonfire.com/
Old 06-16-2009, 10:09 PM
2beers4me's Avatar
I don't know if t would be any better than your mag mount, but I use one of those Radio Shack model 20-176 antennas in the attic. It's the other outdoor model they offer besides the discone. VHF comes is great. I think that is were it does the best actually. At the same time I don't have much to compare it to. It's my first and only external antenna. I do know that it's night and day over the stock rubber duck that came with my Icom R-10, or the telescopic handheld whip that Radio Shack sells. They are not very big, and can fit in a shallow attic. They are pretty cheap at $27.00. I wish I had a discone to compare it to. I always wanted to know if one would do any better for me. I listen to everything not just VHF. If anyone has compared the two please message me the results of the test.
Old 06-16-2009, 10:13 PM
Send a message via MSN to wise871
I second the RS 20-176. I have 4 in my attic and there great antennas. Besides being smaller than the discone, they have great range.
Dan M
BCD396XT / BCD996XT / BCD996T / BCT15 / PRO-197
Old 06-17-2009, 07:26 PM
I had forgotten about the mighty RadioShack 20-176. It is also an great antenna at a great price, I had one myself many years ago when I lived in Colorado to hear Colorado State Patrol when they were operating over VHF Hi.
Old 06-18-2009, 10:49 AM
ridgescan's Avatar
This is an exchange between carmen and base in Oakland at the tail end of a 147-car lashup. I am in the Sunset district of San Francisco. The Oakland yards are 13-15 miles as the birdy flies from my home. This is the performance of a Diamond Discone. A few people like to downtalk this antenna, but IMO it's a great all-around worker. I am not sure, but I think those carmens' handhelds don't run on a repeater? You can tell in the video their signals are considerably weaker than the base.
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
dual Diamond D-130Js on the roof
...being "comfortable in my delusion"-THANKS!!
Pro 2066 in the truck with glassmount
73s-I am Frank
Old 06-18-2009, 02:33 PM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
What I have suggested (and is probably the cheapest option) is to build a J-pole antenna out of some copper tubing. I have several of these things, and they're easy to make.
J POLE ANTENNA DESIGN CALCULATOR by K4ABT
They dont need a ground plane and they will fit nicely in an attic.
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Rules and guidelines for forum post content
Similar Threads
antenna in attic? bfossett Antennas and Coax Forum 4 04-19-2009 10:31 PM
Advice on running wire from attic antenna to basement static-line Antennas and Coax Forum 9 10-30-2008 08:49 PM
Attic antenna yank24 Antennas and Coax Forum 5 10-05-2008 08:00 PM
Antenna: Attic Or Outside gorak Antennas and Coax Forum 2 03-28-2007 07:13 PM
