Go Back   The RadioReference.com Forums > Service Specific Monitoring > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum - This is the place to discuss monitoring railroad communications.
  #21 (permalink)
Old 10-17-2011, 4:25 PM
burner50's Avatar
The Third Variable
Originally Posted by PJH View Post
Eh, tell me about it... Though does make a nice place to put your bag...though the ice box behind the seat does suck, I've come to realize..
Indeed...
It makes it very difficult to assume the standard conductor position.
RadioReference.com Forums Moderator
burner50@radioreference.com
  #22 (permalink)
Old 10-18-2011, 9:51 AM
Last PTC doc I had (will need to dig it up) stated that they settled on 220...at least for the Class 1's. There was talk about interoperbility between the RR's and manufactures.
J, had an older AC4400 the other day that already have the PTC breaker installed on the back panel, nothing else obvious though.
UP according to their FRA submission is suppose to start installing it in loco's at 1000? a year for most loco models.
I think some of that stuff (PTC breaker) is standard equipment anymore. A couple of our engines have breakers for cab signals, cab signal acknowledgement reset, and stuff to cut the cab signals out.
Tim
  #23 (permalink)
Old 10-18-2011, 7:20 PM
burner50's Avatar
The Third Variable
Interesting... I never got on many foreign engines.
However, I did notice today that a Cattron chest pack is labeled 220Mhz, and I know they use repeaters for those...
  #24 (permalink)
Old 02-02-2014, 12:22 AM
Default PTC Frequencies
To the Group:
Finally found the PTC lease agreements on the FCC website. I submitted this info to the RR database, but some of it appears to have been corrupted in the posting process. Thought I'd post it to this thread for general information. The actual frequencies licensed in the 220 MHz band are as follows:
Temporary Fixed ----------------------------- 220.1275
Temporary Fixed ----------------------------- 220.1325
Temporary Fixed ----------------------------- 220.1375
Temporary Fixed ----------------------------- 220.1425
Temporary Fixed ----------------------------- 220.1475
Mobile and 6.1 meter control station - 221.1275
Mobile and 6.1 meter control station - 221.1325
Mobile and 6.1 meter control station - 221.1375
Mobile and 6.1 meter control station - 221.1425
Mobile and 6.1 meter control station - 221.1475
Temporary Fixed ----------------------------- 220.7525
Temporary Fixed ----------------------------- 220.7575
Temporary Fixed ----------------------------- 220.7625
Temporary Fixed ----------------------------- 220.7675
Temporary Fixed ----------------------------- 220.7725
Temporary Fixed ----------------------------- 221.7525
Temporary Fixed ----------------------------- 221.7575
Temporary Fixed ----------------------------- 221.7625
Temporary Fixed ----------------------------- 221.7675
Temporary Fixed ----------------------------- 221.7725
Mobile ------------------------------------------- 221.7525
Mobile ------------------------------------------- 221.7575
Mobile ------------------------------------------- 221.7625
Mobile ------------------------------------------- 221.7675
Mobile ------------------------------------------- 221.7725
Dan
  #25 (permalink)
Old 02-02-2014, 12:47 AM
Jay911's Avatar
Canadian Pacific has had the following batch of frequencies licensed at their Calgary, Alberta, Canada main yard for about a year now. 17K8DXW is the emission designator.
220.13750 MHz
220.41250 MHz
220.43750 MHz
220.71250 MHz
220.73750 MHz
220.76250 MHz
It's the only license nationwide. Nothing's been detected on any of these freqs by my scanners.
--j.
@Jay91150 and @RMESFire | http://www.rmesfire.org
  #26 (permalink)
Old 02-02-2014, 1:51 AM
PJH's Avatar
PJH PJH is offline
Global Database Admin
Originally Posted by WA3ATV View Post
To the Group:
Dan
What is the licesne? I wouldn't put too much credence in those freq's just yet, especially with the temporary designation. On the railroads I know, nothing has been done at the field level too much yet due to backend work that is still needed to bring it online.
In my neck of the woods, the equipment shelters, antennas, cabling etc have been installed for two years, but there are no radios installed yet due to technical issues. Locomotives are being retrofitted with radios and equipment, but wayside, not so much.
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
  #27 (permalink)
Old 02-03-2014, 1:51 AM
The frequencies are directly from the FCC's ULS database. That's about as credible as you can get.
Dan
  #28 (permalink)
Old 02-03-2014, 2:10 AM
Thanks Jay! That's good info. Looks like two of those frequencies agree with what they're licensing here. The others are new! I'll poke those in my scanner too just in case as we have some D&H in my neck of the woods.
Dan
  #29 (permalink)
Old 02-03-2014, 6:04 AM
Default PTC
PTC uses the 220 frequencies as its primary communications link when the train is on the road. It uses WiFi for yard comm, with cell as backup for both.
By the way, PTC was MANDATED by congress back in 2010(or there 'bouts). At the time the congressonal budget office predicted that there was NO payback (ie, it was not economically feasable) to do the program, but congress approved it anyway. The RRs did not initiate it. It is supposed to be fully implimented by 2015 (for all passenger service and most major freight lines), but that probably will be delayed for several reasons.
  #30 (permalink)
Old 02-03-2014, 6:51 AM
if the above is true why is NS pushing ATCS now and implementing it so heavily
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
  #31 (permalink)
Old 02-03-2014, 8:17 AM
burner50's Avatar
The Third Variable
Default Positive Train Control Frequencies
Does trip optimizer use the same equipment / frequencies?
We have one run that is TO equipped. It keeps tearing trains up.
  #32 (permalink)
Old 02-03-2014, 9:36 AM
PJH's Avatar
PJH PJH is offline
Trip optimizer is like leader using gps and terrrian. I've only seen one and it wasn't used.
Other posts...
What license in the database was assigned to those freq?
PTC isn't used in the yards. There is "wifi" at certain locations and is used for event recorder downloads, and updates for the LEADER and Trip Optimizer system, if equipped. It is also used for remote diagnostics if also equipped.
Cell based systems are used for remote diagnostics as well, if equipped, and has nothing to do with PTC.
220 and UHF can be used in yards for RCL equipment, depending on the manufacture and may use repeaters so don't get confused if looking at FCC data in many locations.
  #33 (permalink)
Old 02-03-2014, 9:38 AM
PJH's Avatar
PJH PJH is offline
In the most modern EMD or GE locomotives there will be a string of cables labeled:
VHF, 220, UHF, 900, GPS. There are about 6-8 antenna for all the functions requires.
  #34 (permalink)
Old 02-03-2014, 10:19 AM
PJH's Avatar
PJH PJH is offline
PTC is a "thall shall not pass go" authority system. ATCS isn't. ATCS with other software subsystems is an extension of CAD.
  #35 (permalink)
Old 02-03-2014, 12:21 PM
Default PTC License
PJH,
(Sorry, I didn't get your name.)
The licenses (there are two) are issued to "PTC-220, LLC" which is the holding company the railroads set up to "buy" the auctioned spectrum.
The call signs are: WPFP444 and WPFR284.
The links to the license information in the ULS are:
ULS License - Nationwide Commercial 5 Channel, 220 MHz License - WPFP444 - PTC-220, LLC
and
ULS License - Nationwide Commercial 5 Channel, 220 MHz License - WPFR284 - PTC-220, LLC
There are eleven leases listed so far, including BNSF, CSX and NS. When someone buys spectrum and leases it to others, copies of the lease agreements must be filed with the FCC similar to the way one would file a license application. These lease agreements are also available for inspection in the ULS. By way of example, here is a link to a copy to one of the two lease agreements (two pages) filed with the FCC for NS:
http://wireless2.fcc.gov/UlsApp/lett...ull&letterTo=L
Hope this helps answer your questions. I hope that railroad and scanner enthusiasts will begin to monitor these frequencies for activity.
Dan - WA3ATV
  #36 (permalink)
Old 02-03-2014, 12:28 PM
burner50's Avatar
The Third Variable
Remote Controlled Locomotives also use 220mhz frequencies.
  #37 (permalink)
Old 02-03-2014, 12:29 PM
PJH's Avatar
PJH PJH is offline
One of the applications of the LLC is the director of PTC for NS. These may be for NS, but there is lots of different ways of doing stuff.
Most railroads (especially the west coast ones) will go and lice sense stuff themselves. In the past AAR use to do blanket licensees, but if you take sample licensees for the voice channels, the RR's are doing it themselves these days.
The nationwide licensing may be for the NS locomotives more than the base stations. The goal of PTC in the backroom/specification is to allow any locomotive, regardless of vendor, to operate on any railroad.
You can say its like the P25 data standard, for railroad.
I'll do some more research, but I think that may be the case here.
  #38 (permalink)
Old 02-03-2014, 12:32 PM
Default PTC - ATCS
reconrider8,
(Sorry, didn't get your name either.)
PTC is an overlay of existing signalling systems. It does NOT replace them. Thus, it makes no difference whether those systems operate via ATCS, copper wire, fiber, microwave, satellite or sub-space radio. PTC augments the existing system (in whatever form) with new capabilities. Thus, NS moving from copper to ATCS or CSX moving from ATCS to satellite has no significant bearing on the implementation of PTC.
Dan - WA3ATV
  #39 (permalink)
Old 02-03-2014, 12:38 PM
There are three licenses. You missed this one.
ULS License - Nationwide Commercial 5 Channel, 220 MHz License - WQSK949 - PTC-220, LLC
Oh. It looks like this one is only for Illinois.
Tom
  #40 (permalink)
Old 02-03-2014, 12:39 PM
PJH,
(Still didn't get your name.)
"One of the applications of the LLC is the director of PTC for NS."
Correct! That's to be expected. "PTC 220 LLC" is a holding company established by a consortium of the railroads. If you browse through the PTC 220 LLC filings, you'll also find mailing addresses in Norfolk and Jacksonville.
At any rate, there it is. Unless anyone has any actual, factual information to the contrary, those are the PTC frequencies recognized by the FCC as of today.
Dan
Dan
