Go Back   The RadioReference.com Forums > Service Specific Monitoring > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum - This is the place to discuss monitoring railroad communications.
  #21 (permalink)
Old 03-23-2016, 6:45 PM
Hi Eric,
Are you saying that after the updater has finished, I then have to re-program the radio with the RR CS? Darn, that makes sense too. I didn't even think of that as I figured the radio was "already programmed".
After the firmware update, the radio display was flashing and the top LED was flashing, and the display said "CLONE NC", so I just "assumed" that it wasn't successful.
Thanks; will try it again when I have that radio in my hands.
  #22 (permalink)
Old 03-23-2016, 6:48 PM
Darn Josh, I totally missed your allusion to that as well. Thanks!
  #23 (permalink)
Old 03-24-2016, 10:20 AM
Originally Posted by Cognomen View Post
Hi Eric,
Hello,
The data structures are likely different between the two, since the RR version has different features. The best method would be to do a factory reset to clear the memory and put in default values, but I do not know if this is possible with this radio. Regardless, you need to recreate your codeplug in the RR version of the Cloning Software.
73 Eric
  #24 (permalink)
Old 03-25-2016, 6:15 PM
That was it.
Reflashed the RR update, got the blinking radio and "CLONE NC". Loaded up my existing RR .icf from my other radio and programmed it into the "new" RR radio. Done.
  #25 (permalink)
Old 11-09-2017, 7:12 PM
Default ICOM 3161 and 5061
I have both radios but not the RR Firmware. I need the RR Firmware. I contacted my dealer. And they provided me with the RR cloning software, but my rep doesnt seem to understand there is a firmware update as well.
Does anyone know where i can get said firmware?
  #26 (permalink)
Old 11-10-2017, 6:28 AM
RRR RRR is offline
NS doesn't even use the "Railroad" / "AAR" software on the new NXDN capable radios.
  #27 (permalink)
Old 11-10-2017, 7:38 AM
Whistler trx1 and trx2 does NXDN and railroad channels. No extra firmware or purchase needed.
And can be used without the worry of accidental transmitting.
  #28 (permalink)
Old 11-11-2017, 2:23 AM
burner50's Avatar
The Third Variable
There's no need to worry if you program it with no transmit frequency.
RadioReference.com Forums Moderator
burner50@radioreference.com
  #29 (permalink)
Old 11-16-2017, 8:20 PM
Whistler has the new TRX-1 and TRX-2 Mobile out with a NEXEDGE update.
