Go Back   The RadioReference.com Forums > Service Specific Monitoring > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum - This is the place to discuss monitoring railroad communications.
Old 04-19-2017, 12:28 PM
Priority-One's Avatar
Default Metro north and Amtrak
Do MNRR and Amtrak communicate via radio?
I take the train a lot from Manhattan and we always pass the Acela train and it flies by us within inches on the next track.
Do they ever communicate or know that another train is coming at high speed?
Providing the broadcastify feed for the 25/28/32 pcts in Harlem.
Old 04-19-2017, 2:20 PM
Yes they communicate via radio. The proper channels are listed in the rr database. Unless there's a problem, trains don't really talk to each other. I have ridden from NYP to Washington equipped with my radio and outside of inbound NJT trains getting radio checks from PSCC or CTEC-9 there isn't much chatter.
Old 04-25-2017, 7:44 PM
Not usually why would they need to know,. Thats what the Dispatcher is for
Also MNR also does not use the radio as much as amtrak and others
Old 04-26-2017, 12:03 PM
Location: New York North Carolina and all points in between
Metro North uses signals most of time except for work crews or other problems on the tracks. The radios are busy enough with out any extranious transmissions such as 2 trains passing one another. Speed limits are set for a section of track so each train knows how fast they may go.
To add to this we do have a single base station available to the RTC for direct contact on Amtrak's frequency.
Old 04-26-2017, 12:05 PM
Sorry for my ignorance, I'm new to rail scanning
Old 05-22-2017, 8:17 AM
N1SQB's Avatar
Hey, you never know until you ask. We have the privilege of having some experienced people on this subject on here, some of which already gave you responses.
Manny
N1SQB-AMATEUR EXTRA
The difference between men and boys, is the price they pay for toys!
Old 05-22-2017, 9:04 AM
Hello,
It can be alittle unnerving to suddenly have a high-speed train pass by since you do not know it is going to occur. The engineer sees the track ahead and there should be clearance between the two tracks, so no problem.
As mentioned the radio is used for work crews, various trackside detectors, and to communicate changes to the train crew. Trains are mandated to implement a Positive Train Control (PTC) system. AMTRAK uses ACSES, which handles many of the communications between the train and the office. Metro North is implementing the same system for PTC.
https://en.wikipedia.org/wiki/Advanc...rcement_System
73 Eric
Old 05-22-2017, 7:05 PM
if its passing a stopped train the engineer is supposed to whistle
