Go Back   The RadioReference.com Forums > Service Specific Monitoring > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum - This is the place to discuss monitoring railroad communications.
Old 10-09-2017, 2:30 PM
Location: New York North Carolina and all points in between
Default Opinion of Ritron Clean Cab
Our agency is looking at new Clean Cab radios. There is the Quest Rail,Railcom, Ritron and probably some others, but I am looking for input from users (Railroad Engineer types) of the Ritron Clean Cab. I just went over there programming manual and it appears to be pretty descriptive as to what the radio is capable and not capable of. We don't need 90% of what is in the radio, no need for DTMF or any other tone signalling except PL so what I am looking at what others think of it's ease of use, receive volume and clarity, display, built in microphone gain and noise rejection on analog mode only, also changing channels on the fly and the use of Home channels instead of AAR presets.
I would prefer to hear from actual users rather than hearsay or sales people.
Old 10-10-2017, 6:29 PM
nickwilson159's Avatar
I worked for a shortline that was using GE 12RII clean cab radios when I got there. They had poor range, were very susceptible to intermod, and the audio wasn't the best. I polled some engineer friends at CSX, NS, and CP, and all seemed to like Motorolas the best, followed by Ritrons. We purchased two Ritrons to test, and were told that the audio was better (louder & clearer), better reception, and the intermod issue disappeared completely. We eradicated the GEs with more Ritrons and some used Astro clean cabs from CSX. Didn't have any complaints about ease of use as compared to the GEs or Motorolas. Can't comment on home channel use since we didn't use them. Display is clear & bright.
With that said, the Ritrons' weakness is noise rejection. In older, loud, rattling locomotives, you don't hear much besides cab noise.
Full disclosure: part of the range issue was probably due to the Motorola HT750s being used when I got there as well. These were replaced with Kenwood TK-2180s.
Old 10-12-2017, 5:28 AM
The GE 12RII I use have a couple issues. The main one is the PTT will stick. People have resigned over what was said when that PTT was stuck. Its fairly common problem with our fleet. I have confirmed with engineers/conductors on other railroads and they have experienced the same issue. Next is a no receive issue. The display will say "NO RCB DETECTED". When this is occurring the radio is basically useless until re-started. The radio doesn't beep or signal that something is wrong with it. Both of these issues have been reported for the last 9 years. Our mechanical forces change out the remote head, but the problem still occurs.
We utilize the home channels. It great just hitting channel up or down. We use 2 channels often and switch back and forth. Not very often we have use the "AAR" button. We do have one home channel that has PL encode, it works just fine. The TX/RX audio is great. Good noise cancelling and even better when use the phone style microphones.
We also have a fleet of Ritrons. To me, they are the replacement to the Motorola Spectra. Similar design and radio operations. Speaker is loud. The internal microphone will pick everything, best to use a handheld style mic to get rid of the background noises. Home buttons are what we mainly use. The only bad thing I have seen with them was during a engine start up. It seems during the start up the radio locked into TX mode. I'm suspecting low voltage during the engine turning over, but not for sure. Those radio's were TXing for days before someone finally found them. They were hot, but they still work today.
Tim
Old 10-12-2017, 6:37 PM
When i worked for Whelen 1996 we used the little ritron data radio in the large outside siren. They were not bad radios. some were goofy some were not.
But look at how many Aerotron radios the Railroads have used over the years
Old 10-13-2017, 11:17 AM
W9BU's Avatar
Lead Wiki Manager
Seems like one of the available clean cab locomotive radios is actually a Kenwood mobile in a clean cab box with a power supply and modified user interface. Is that correct?
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 10-13-2017, 8:00 PM
Default Ritron CCR
Hi Radioman,
Sent you a PM.
Bill
Old 10-16-2017, 1:40 PM
Either a Kenwood or ICOM mobile radio guts, yes.
Old 10-16-2017, 5:07 PM
PJH's Avatar
PJH PJH is offline
Global Database Admin
I've used the GE's, the JEM, Motorola and RITRON.
What Tim said on the GE's. Avoid.
JEM has a Kenwood or ICOM core, though I think they have mostly went to Kenwoods. They work, but the display is small and runs together. I am not sure if any custom display names can be had, but I don't care for them - but that's all that are bought.
The RITRON's I've played with in the field and at IWCE in the past. Nice loud audio and nice bright display screen. As stated above, seem to be the one to go to as a Motorola replacement.
When I spoke to the factory reps at IWCE moons ago, they stated they built theirs from the ground up, whereas most others are just a mobile radio with the custom clean cab head (Motorola, Nexterma/JEM). I am not sure if GE's are repackaged as well or not.
So, unless you need alpha display names, the RITRON is a very good radio, straightforward and simple to use.
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
Old 10-17-2017, 3:35 AM
I would use the GE radio over the JEM crap. We only get the JEM stuff on foreign power. Takes forever to just change a channel.
Tim
