Suburbia: A shortwave radio enthusiasts nightmare, what with switch mode power supplies and plasma TVs and cable modems spreading misery across the HF spectrum. Then add a healthy dose of terror if you live in a rental property that has a 'no CB antennae' clause. Welcome to my RF hell for the last three years.
After suffering from radio withdrawal symptoms for so long, I finally decided to do something about it. While my little Degen / Kaito 1103 with a 10 foot indoor longwire running along the curtain rod was OK, it suffered badly at the hands of neighbourhood plasma TVs and swithmode power supplies - cell phone chargers being some of the worst. I got a PAR EF-SWL antenna, and installed it stealthily along the back fence line, optomised the earthing for lowest noise & interference, and buried the coax to come inside. In some cases the EF-SWL was better than the indoor random wire, sometimes not.
Dismayed even after having done everything right with the EF-SWL and still not achieving the desired result, I'd almost given up hope of sinking my teeth into some decent and noise free shortwave listening... when Wellbrook come to the rescue with their active loop the ALA1530. Now things are looking up, as the below video demonstrates. The ALA1530 isn't perfect, it won't completely rid your life of every bit of interference. But in some circumstances, especially at lower frequencies, the ALA1530 was rejecting noise far better than the EF-SWL. And in my testing from 200 kHz to 29 MHz, the ALA1530 always had a 2 to 6 S-point advantage over the EF-SWL which was very suprising. Most importantly though, the ALA1530 without exception produced a signal that was as listenable or better than that delivered by the EF-SWL.
As I play with the Wellbrook, learning its limitations and advantages, I'm liking it more and more. No, it's not perfect, but then what in life is? But it is very very good, and perfect for those who live in the urban jungle looking for a quiet or stealthy antenna.
Wellbrook ALA1530 vs PAR EF SWL 160mtrs with plasma TV interference - YouTube
