Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Receive Antennas (below 30MHz)
Receive Antennas (below 30MHz) - For all topics related to receive antennas used on HF, MW, LW, etc. For transmit antennas use the Amateur Radio Antennas forum.
Old 07-27-2017, 10:15 AM
mbott's Avatar
Default Mounting a Wellbrook
Came across this pic and I thought I would share it here. I have used this to mount my Wellbrook on a rotor and it seems to provide plenty of support.
Knight Star Roamers Sony ICF-2010 Sangean ATS-909X Icom IC-R75 Tecsun PL-660 Kenwood R-5000 Yaesu FRG-7 SDRplay RSP1&2 JRC NRD-535D CountyComm GP-5
Pixel RF Pro-1B JTD1 discone Wellbrook ALA1530NP
Old 08-12-2017, 10:20 AM
Hello,
Thanks for posting. I bought the adapter and then it was off to Home Depot for PVC hardware. I am using a speaker stand, so I bought a 1/2" x 3/4" reducing male adapter, a 3/4" coupling, and 3/4 inch pipe. The PVC adapter and coupling fits in the tube of the speaker stand. The pipe is used as a spacer. The "nut" on the PVC adapter prevents the assembly going completely into the tube. I am going to drill a hole through the coupling that lines up with existing holes in the tube and put a bolt through to hold it.
73 Eric
Old 08-15-2017, 4:46 PM
mbott's Avatar
Pictures?
