Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Rhode Island Radio Discussion Forum
Rhode Island Radio Discussion Forum Forum for discussing Radio Information in the State of Rhode Island.
Old 06-26-2008, 09:50 PM
Default Help with a Pro96 and RISCON
I knoticed the other day that my Pro96 has not been picking up any traffic from the new network all of a sudden. When I went to the control chan it was scilent and took a long time to pick up the Digital signal. It didnt even show me the signal strenght % like it used to.
Any ideas what could have happend in the programming or did my scanner just die. This scanner has always been fininky with the new digital system.
I do have the 800mhz antenna and I am located in South Kingstown on the Narragansett line, wich is close to the RISCON souther tower (acording to database on here).
Thanks in Advance
Old 06-27-2008, 04:45 PM
Thanks in Advance
Did you try the alternate control channels to see if they had switched?
868.15000 868.27500
B.K.
Old 06-29-2008, 08:05 PM
Sorry for the typos in the first post I didn’t see them until after I could no longer edit it. I meant to say
I noticed the other day that my Pro96 has not been picking up any traffic from the new network all of a sudden. When I went to the control channel, it was silent and took a long time to pick up the Digital signal. It didn’t even show me the signal strength % like it used to.
Any ideas what could have happened in the programming or did my scanner just die. This scanner has always been finicky with the new digital system.
I do have the 800 MHz antenna and I am located in South Kingstown on the Narragansett line, which is close to the RISCON southern tower (according to database on here).
Thanks in Advance
868.15000 868.27500
B.K.
Thanks for the advice. No the control channel is still the same. My scanner all of a sudden just started taking a long time to decode the digital signal after I turn it on.
Old 06-29-2008, 08:17 PM
RobKB1FJR's Avatar
Send a message via AIM to RobKB1FJR Send a message via Yahoo to RobKB1FJR
Coverage areas on the system are very spotty in the North/South Kingstown areas. I know up at Kingston Bowl I could barely receive the system.
Equipment: Combination of junk radios and new radios.
Old 06-30-2008, 10:22 AM
Do you have any way of comparing your antenna's performance on other frequencies in you area. eg. weather channels? The Pro-96's have had problems with the internal connection of the antenna to the circuit board coming loose causing similar symptoms as to what you experienced.
B.K.
Old 06-30-2008, 05:21 PM
B.K.
I am still picking up SK PD and FD loud and clear without any problems at all. I am using the 800mhz antenna too.
