Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Rhode Island Radio Discussion Forum
Rhode Island Radio Discussion Forum - Forum for discussing Radio Information in the State of Rhode Island.
Old 03-24-2013, 11:13 PM
Question Can't get RISCON
I'm having an issue here.... I have a BC796D. i CAN get Coventional Trunking (Mass State Police), Coventional Digital Pawtucket and Dartmouth PD's), but i can NOT get the RISCON. I had the scanner sent out within the past month or so and got Providence FD when i got it back but once i put it back in the car, no more. ideas??????
Old 03-26-2013, 9:59 AM
PaulD's Avatar
antenna and location has a lot to do with it i can receive them most of the time in my truck but in certain areas of the state i lose the repeater signal however all the other riscon frequencies come in good all the time good luck
paul durocher
Old 03-27-2013, 9:22 AM
MisterK33's Avatar
Wish I could help you
Baofeng UV-5R+ w/Nagoya antenna & modded 3800 mAh battery
GRE PSR 500
Sony ICF-SW 7600
Old 03-27-2013, 10:14 AM
Unhappy
I have the same problem with my Home Patrol 1. I'm also looking for an answer. I have the latest firmware and database. Being located on the MA/RI border, I get great reception using a ST-2 antenna on the roof. So, I can't imagine why I do not get RISCON.
Old 03-28-2013, 6:16 AM
ecps92's Avatar
As PaulD posted... location, location, location.
Have you gone mobile near one of the sites, so as to confirm it is not a defective radio.??
With RISCON being a simulcast system, and designed for Commercial/Public Safety radios, different scanners handle the multi-path differently. Some poorly
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 03-28-2013, 6:35 AM
Is it true that the RISCON system uses omnidirectional antennas?
Old 03-29-2013, 6:46 AM
No, I haven't. I guess that will have to be my next step. Although I get great reception of stations well over 20 miles away. I'm also going to raise the antenna another 10 feet.
Old 03-29-2013, 7:10 AM
Bill (ECPS), Ive gone ALL over the place. from Fall River to Prov out to Lincoln and down to Warwick. Im able to get Dig Conv, Analog Trunking but not RISCON. Ive have uniden do a firmware update and still nothing.
Old 03-29-2013, 9:51 AM
Default Cant hear RISCON
I found that was apparent with Prov FD. I find the PFD spotty and sometimes non existant about 10 miles away @ home ( on my Home Patrol with a mobile antenna dedicated to RISCON). PFD in my car is OK in the city and weakens the further out you go
The simulcast North and South is great @ home and good in the metro RI area when I am in my car
Old 03-30-2013, 6:28 AM
MisterK33's Avatar
Default Re: Can't get RISCON
I haven't really had a problem with RISCON. In fact, I was driving home from Taunton, MA, and caught a signal about 20 miles away from the transmitter with my PSR 500 and 800 MHz antenna in the truck.
GRE PSR 500
Sony ICF-SW 7600
Old 03-30-2013, 9:42 AM
Have you checked to see if you are using the correct trunking tables in your scanner(P25)? Also do you get a control channel carrier if you check in conventional mode? If not its a reception problem of some kind otherwise check the tables.
B.K.
Old 03-30-2013, 10:24 AM
w1kne's Avatar
NewEngland DB Admin
W1DBC, you haven't mentioned what model of scanner you are using?
Is it one that can handle the 9600 baud control channel (a true P25 system)?
Also if you listen to just the control channel in analog audio mode, can you hear it?
Mike Fitzpatrick
Southern New England DB Administrator
Broadcast Transmission/RF Engineer
Old 03-31-2013, 9:18 AM
OP says 796D.
Old 04-01-2013, 9:10 AM
ecps92's Avatar
Some folks have good luck, others not such luck , because of the Multi-Patch I would say see what you get closer to one of the Towers
Bill N1KUG
