Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Rhode Island Radio Discussion Forum
Rhode Island Radio Discussion Forum - Forum for discussing Radio Information in the State of Rhode Island.
Old 06-15-2017, 3:49 PM
Default RI Nat'l Grid
I have the Grids' LTR system programmed for some time. I watched a troubleman work a wire down today. They was plenty of Northern RI communications. Any thoughts on regaining the ability to listen to the Grid??
Old 06-16-2017, 8:40 AM
ecps92's Avatar
No Scanner can Trunk-Track a Passport LTR
The only option is to program in all the known Frequencies and listen in conventional mode, you just won't know what TG is being used.
Also, some of the newer NGrid LTR are using Part 22 Paging channels and even tho your scanner may show/handle 25 Khz and 12.5 Khz channels, many of these are now using 6.25 Khz channels spacing.
You might want to review exactly what Freqs from both the RRDB and the SNE Wiki's
you have programmed in....
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 06-16-2017, 10:21 AM
Thanx for the info
I will try programming conv. channels. I seem to remember trying that once before. I dont recall hearing any voice just an occasional burst of data or control
As far a radios I use a 996XT, Home Patrol 1 and a GRE PSR400 @ home and a Whistler 1098 in the car
Old 06-16-2017, 10:25 AM
ecps92's Avatar
Yes, when not actively used, there is the LTR Pulse emitted every few seconds.
Thanx for the info
Bill N1KUG
