Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > Sacramento Valley Area Discussion
Sacramento Valley Area Discussion - Local area specific discussion for Sacramento County and its outlying areas such as San Joaquin and Stanislaus Counties.
Old 07-31-2014, 7:08 PM
Default Sac city fire question
I am able to pick up the dispatch and B2 not I am not able to get any traffic on any of the tac channels did I, or am I doing something wrong?
Old 07-31-2014, 7:39 PM
Sac916's Avatar
You can monitor B6 on Site 1 via Talk Group 47664
B6 and other tac channels, are only used for "larger' scale or incidents requiring a lot of communication/coordination
Old 07-31-2014, 7:43 PM
Thanks for the quick reply I was listening earlier this morning and they were assigned to B6 and I wasn't getting any traffic from it I will keep listening and hopefully will get something thanks again for the quick reply
Old 08-01-2014, 11:57 AM
mcjones2013's Avatar
Check your sites, then your talk group IDs, then your lockouts.
Michael Jones | Sacramento, Calif.
Radio Communications Geek | Uniden...all day, everyday.
Old 08-02-2014, 2:44 AM
gmclam's Avatar
Smile Sacramento Fire B6
You should take note that there are actually TWO B6s. One is labeled "B6 Patch" and that's where I usually hear most B6 traffic. Program in both TGs (they have different TGRP codes) to make sure you receive the traffic.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 08-02-2014, 3:14 AM
The original FT B6 is no longer listed in the database.
Old 08-02-2014, 4:07 AM
kma371's Avatar
Global DB Admin
47664 took it's place
Old 08-02-2014, 10:40 AM
I know it was removed I was referencing the above message saying add both talk groups. He can't since it not in the database.
Old 08-07-2014, 1:30 PM
Default Still not getting Sacramento City fire tac channels
I am using the uniden bcd396xt I am getting the dispatch but not getting B2 or any tac channels is anyone using this scanner having this problem? Please if anyone help me solve this issue the help would be much appreciated.
Old 08-07-2014, 2:04 PM
Sac916's Avatar
I just heard traffic twice on B2 Site 1 on my 396XT ...and again while typing this (from downtown ). TG 59280
Sent from my Android via Tapatalk app
Old 08-07-2014, 2:43 PM
Can I ask you how you have your band plan set up on your scanner?
Old 08-07-2014, 3:16 PM
Sac916's Avatar
I know the band plan is buried in the threads. Maybe in the rebranding thread. Anyways I will have to look at my setup via FreeScan to see it.
It is not uncommon to miss traffic on a scanner .. But you should be getting something. I've got 100% signal on site 1 and hearing "most" B2 traffic on the scanner.
Old 08-07-2014, 6:54 PM
Sac916's Avatar
My settings:
Control Channel = Only
APCO Mode Auto
Threshold = 8
State = Off
Hold Time = 0
Modulation = Auto
P25 Wait Time = 400
Motorola Type II / P25
Here is my bandplan
Old 08-07-2014, 7:07 PM
Alright and thanks that is how mine is set up just not understanding why I cant get anything but the main dispatch well thanks again
Old 08-07-2014, 7:09 PM
Sac916's Avatar
If you use FreeScan, I can send you a file to see if that works -
Old 08-07-2014, 7:30 PM
I actually do not have access to a computer when I programmed it I did it manually maybe I should just clear the memory and retry to reprogram it again
Old 08-07-2014, 7:38 PM
Also when I reprogram it do u think I should put the sites frequencies together or should I just be able to use site one for city and and site 2 for all the county
Old 08-07-2014, 8:15 PM
kma371's Avatar
Global DB Admin
Set them up as different sites because they are different.
What firmware is your scanner using? This sounds like a band plan issue.
Old 08-07-2014, 9:09 PM
Sac916's Avatar
I'm running Running firmware 1.08.14
Here is how I have mine set Fire Systems set up --
http://i.imgur.com/f2hruIE.jpg
Keep Site 1 and Site 2 separate - Do not mix frequencies
You do not want 2 control channels running on one system
I think I might have said it earlier, but be sure to monitor Site 1 if you want to hear all/most of Fire B2 radio traffic
Old 08-07-2014, 9:34 PM
I am running version 1.11.01
