Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > Sacramento Valley Area Discussion
Sacramento Valley Area Discussion - Local area specific discussion for Sacramento County and its outlying areas such as San Joaquin and Stanislaus Counties.
Old 10-11-2017, 4:54 PM
Exclamation Santa Rosa Fire
I am in Bennet Valley, the line of the Tubbs fire in Santa Rosa, California. I am having problems with which frequencies/agencies i should have entered in my scanner to monitor the fire efforts. They quit discussing their efforts on the local fire channels days ago and i am in the dark now. All i am hearing is evacuation efforts and the standard police chatter for lootings. I am interested in the fire supression efforts, and movements.
Any one know who(m)/what agencies i need to monitor? Cal fire? etc.
Also any freq's for Air traffic related to fire efforts.
any help is appreciated.
Also Apologies if i am posting in the wrong forum. some direction towards the right one is also welcome.
TIA
Jappee
Radio Shack Pro-107 w/ ISCAN
Old 10-12-2017, 8:34 AM
Ensnared's Avatar
Default Santa Rosa Fire
For some reason this did not post earlier.
I see that you are using a Pro-107 scanner. After reviewing the county where you reside, I would imagine some of the activity has moved to various interop channels. With you radio, you won't be able to hear anything marked with "NAC." But, you might get lucky with the others. https://www.radioreference.com/apps/db/?aid=7742
"Born to Lose, Lived to Win" Lemmy Kilmister
Old 10-12-2017, 8:59 AM
kma371's Avatar
Moderator/Global DB Admin
TIA
Jappee
Try the Tac channels for CAL FIRE. They are listed in the database. Same for the air tacs.
Old 10-12-2017, 12:48 PM
ramal121's Avatar
A lot of frequencies are being used for the different fires (really scraping the bottom of the barrel). If you are in Bennett Valley you are being impacted by the Adobe fire. This is part of the southern complex, branch 1. See ICS-205.
Old 10-12-2017, 8:06 PM
stingray327's Avatar
Cal Fire, United States Forest Service, National Interagency Fire Center-USA (lots of Air traffic) Office of Emergency Services, CHP, California Multi-Agency Radio System (CMARS), Military OPS, and Sonoma Co. local freqs for fire and Sheriff's Office.
Same goes for Napa Co. from local to state to federal freqs. (Same as above Sonoma Co.)
Old 10-13-2017, 2:59 PM
gmclam's Avatar
Arrow Sonoma & Napa Co Fires
It depends on the specifics of you want to hear. I have just about everything programmed for the area, and I am hearing lots of traffic here in the Sacramento area.
I'd start with CHP; BLUE, GRAPE, EMERALD.
SONOMA SHERIFF & FIRE DISPATCH
CalFire -- Yeah they have a lot of channels, but this is a huge event.
NAPA CO SHERIFF & FIRE
If local to you, Napa city PD & Fire
If you're on the southern edge, Solano county is good to have.
If you're on the northern edge, Mendocino county is good to have.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
Old 10-13-2017, 3:15 PM
norcalscan's Avatar
Assuming you are Bennett Valley Road, between Santa Rosa and Glen Ellen, as of Friday 13th, you are identified on the fire as the following (working largest area to smallest):
Central Complex -> Sonoma/South Zone -> Branch 21 -> and then either...
Division DD (northern 2/3rd of Bennett Valley Road and all of Annadel St Park)
Division CC (southern third of Bennett Valley Rd near Warm Springs Rd)
Division LL (the spot fire near Crane Canyon Road)
Fire Aircraft
Sonoma/South Air Attack 167.550
Helicopters 119.175
Air Ground Command 159.3325
Air Ground Tactical 169.0875
Fire Com Plan
Command Net Primary 151.250 (tone 103.5) - CDF Cmd 6
Command Net Secondary 151.460 (tone 136.5) - CDF LNU West
Div DD 151.3925 (tone 192.8)
Div CC 154.4525 (tone 156.7)
Div LL 154.265 (tone 156.7)
I have no intel on the Law side of things. Others have posted many suggestions.
Old 10-13-2017, 3:53 PM
ramal121's Avatar
Another command net is 154.220 OES 2B. Another air to ground command 151.3775.
Old 10-13-2017, 4:45 PM
Are those ICS-205 forms publicly available? I saw blank forms from FEMA, but not any filled-out ones for active incidents, either from CalFire or OES.
Wondering where I can see the active incident forms for future reference.
Thanks!
Old 10-13-2017, 6:10 PM
ramal121's Avatar
Thanks!
Not generally available but members on this forum are good at posting info:
http://hotlist.wildlandfire.com/forum.php?
Sent from my SM-T560NU using Tapatalk
Old 10-13-2017, 6:54 PM
norcalscan's Avatar
OES2B 154.220 is for the Southern Complex, which is just the Atlas Fire now near Napa.
151.3775 is Air/Ground Command for the North Zone of Central Complex, which is Pocket and Tubbs. OP's fire is in the Sonoma/South Zone.
The freqs I posted are for the Central Complex and specifically the areas that affect the OP along Bennett Valley Road. It might not be good idea to add two additional very busy frequencies to the scanner that don't pertain to any fire near the OP. They might miss important local info.
As a scanner listener not in direct danger of any fire, by all means listen to everything we can, but for those still in the path, it's usually important to focus on just what's around you.
Old 10-13-2017, 7:27 PM
ramal121's Avatar
I agree and disagree. OES 2B was being used by all, Pocket fire to Atlas using three sites (St Helena, Vaca, and Sugarloaf) along with LNU W. 151.3775 air/gnd was in use for the South (listened as the VLAT flew over, whee!) The OP is now in the central zone.
LNU E, LNU W and XNA are off command duties for this incident for now.
My observation, this is nuts. Every morning brings a new line up on the 205's. Radio assignments change radically each morning, along with with the zones and branches. As a radio guy I should know this but find it hard to keep up.
For the listener that has the inner scoop on things, all well and good. Otherwise plug it all in and pick out what pertains to you.
Old 10-13-2017, 8:05 PM
WildlandFire Hotlist Forums
Apparently you have to be a member to see things...I've been okay with listening but do we know if VTAC's are changing daily too?
Regards,
-Frank C.
Old 10-13-2017, 8:54 PM
ramal121's Avatar
So sign up, it's free.
Tacs have been stable but commands keep jumping around.
Sent from my Pixel using Tapatalk
Tags
santa rosa, tubbs fire
