| San Diego Metro Area Discussion Local area specific discussion for San Diego and Imperial Counties. |
09-11-2012, 7:53 AM
CHP San Diego Conventional
Am I missing anything? I know there is also Blue (42.34), Blue 2 Border Division Wide East (Planned) (44.98), Blue 2 Border Division Wide West (Planned) (39.24) , and TAC 04 (39.92) but I don't have them programmed. All these different blues and PL tones confuse me. What do you have for CHP? Is Blue 1 even used? Should I remove Blue 1 and put in Blue instead? When is TAC 04 used? I've tried listening but theres so little traffic on the blues that its hard for me to figure it out. I am only interested in traffic accidents and pursuits.
Department of the Highway Patrol (CHP) Scanner Frequencies and Radio Frequency Reference
I currently have the following programmed:
CHP BLUE 1-----39.14----FM---CTCSS---162.2
CHP GOLD-------39.60----FM---CTCSS---162.2
CHP ORANGE-----39.40----FM---CTCSS---162.2
CHP TAN--------39.80----FM---CTCSS---162.2
Also, I know the Gold is almost never used.. I have it just cause.
09-11-2012, 8:21 AM
Originally Posted by Stringer619;
_..._
[FONT=courier
CHP TAN--------39.80----FM---CTCSS---162.2[/FONT]
Your list is correct for San Diego County.
The 'original' Blue (42.34) is in use in Imperial County (El Centro dispatch).
09-11-2012, 8:30 AM
So all the other "blues" are unneccessary or unused? And what about the TAC 04? All the pursuits I've heard, other than on the RCS, have been on the Orange or Tan, so when would the TAC 04 (which is labeled as "Base - TAC 4 (Border Area)") or any other channels be used?
When I hear "switch to the blue", they referring to Blue-1 and not Blue?
Orange (San Diego) and Tan (Oceanside / Temecula) are good for their respective areas, but I just feel like I'm missing out on something.
And if 42.34 is El Centro Dispatch, then why does the database list it as Border Division (which I translate as "San Diego"?).
09-12-2012, 5:45 AM
The CHP is completing a lengthy reconfiguration of their low-band radio system. There are now multiple "Blue" channels, assigned by Dispatch Center. As best as I've been able to figure, only the "BLUE" (42.34) and "BLUE-1" (39.14) channel naming conventions are consistent statewide. An area of the state assigned another channel pair for their secondary use will have the channel named BLUE-2 or BLUE-3 [such as " Blue 2 Border Division Wide East (Planned) (44.98), Blue 2 Border Division Wide West (Planned) (39.24)]. The TAC channels are whole different thing altogether (and that onion I have yet to start peeling).
The field units will switch to whatever their assigned BLUE channel is.
We all feel that way. A lot is done via mobile data computers.
BLUE (42.34) is the Blue Channel used in El Centro Dispatch's area (El Centro and Winterhaven Area Offices). Dispatch is on MAROON-1 (42.92).
As to why El Centro is listed as "Border Division" see the map at CHP-Geographic Divisions Page for the CHP's eight geographic field divisions (and Border Division's 12 Area Offices and 4 Dispatch centers).
10-02-2012, 11:49 AM
CHP Border Div
Has it been decieded wether maroon will be repeated?
11-07-2012, 11:26 PM
I shouldn't be giving out secrets, but when you hear agencies say that the "pursuit" is on "Blue 1", they are referring to RCS talkgroup 9040. SD CHP work chases off of their base frequency....in LA and Orange Counties they switch to 39.14, but that is because chases in LA typically go through 3-4 CHP areas.
Paul
11-08-2012, 4:58 PM
California DB Admin
None of that is a secret...
11-08-2012, 5:28 PM
Apparently a bigger secret than we're thinking. It's not in the RCS db unless it's got an alias. Any other Blues not there?
Steve
11-08-2012, 5:36 PM
And LA CHP would never use 39.14 MHz, the would use Southern Blue in their area.
11-08-2012, 6:15 PM
Sorry, 42.34, that is what I meant........and if Stringer619 doesn't know about it, it is a secret. :P
Paul
11-08-2012, 8:12 PM
Steve
Ummm ...
San Diego County - Imperial County Regional Communications System (RCS) Trunking System, Various, California - Scanner Frequencies
San Diego County Law Interoperability Talkgroups
DEC HEX Mode Alpha Tag Description Tag
9040 235 A BLUE 1 Blue 1 Interop
3216 0c9 A BLUE 2 Blue 2 Interop
Looks like they're there to me!
(In this case, the BLUE 1 and BLUE 2 talkgroups are San Diego County Law Enforcement "Blue" talkgroups which replaced the former 153.995 MHz simplex County "BLUE" LE Mutual Aid channel when the RCS was placed into service in 1998.)
Reason: Formatting
11-09-2012, 12:45 AM
Those are CHP Blue channels or San Diego Co's - or both?
Steve
11-09-2012, 4:03 AM
Steve
Steve - CHP now has multiple "BLUE" channels on VHF Lowband.
San Diego County has two "BLUE" talkgroups on the RCS.
They are not common to each other.
Don
11-09-2012, 9:41 AM
Thanks, Don
I just wasn't sure whose Blues they were since it was listed under interop rather than CHP. Hate assuming.
Steve
11-09-2012, 10:19 AM
The Blues on RCS are not CHP TGs. They are countywide for pursuit, BOLOs, etc. When CHP has a pursuit, they normally handle it on their main area freq, but may patch to RCS Blue for other agencies to monitor or assist.
11-09-2012, 11:20 AM
Thanks for the clarification. I misinterpreted Don's answer. So if I have it straight these are SDCo Blue and no direct correlation to CHP.
So does CHP have any Blues on RCS?
Steve
11-09-2012, 3:56 PM
Correct, the Blues on RCS are countywide LE use. CHP only has the TGs in their list, but only uses the El Cajon/Resident ones.
11-09-2012, 4:22 PM
Yeah the BLUE 1 and BLUE 2 on the RCS are by no means a "secret". Nor are the conventional CHP Blue's. Just which conventional Blue's were relevant is what confused me.
11-09-2012, 9:58 PM
Steve
Steve,
Yeah, it can be confusing.
CHP has two consoles on the RCS (El Cajon Area dispatcher and the Link position), with the ability to console patch any of the CHP channels to RCS talkgroups.
Don
12-08-2012, 5:11 AM
Don I have never heard "go to Blue 2". When would Blue 2 be used instead of Blue 1? Can you give a hypethetical? Thanks.
