RCS Database cleanup
JoeyC
Senior Member
San Diego, CA
Hi folks,
Trying to clean up the database so it plays better with the newer database dependent scanners (x36HP, etc).
Recently found some other outdated talkgroups in there and I'm wondering about these.
Does anyone know if any of these are still in radios or in use under the North County Dispatch JPA section?:
28928 710 D NZT 1 North Zone Tac 1 - Training Fire-Tac
28944
711 D NZT 2 North Zone Tac 2 - Training Fire-Tac
80
005 A NZT 3 North Zone Tac 3 - Training Fire-Tac
112
007 A NZT 4 North Zone Tac 4 - Training Escondido Fire-Tac
6000 177 A EFF CMD 1 Elfin Forest Command 1 Fire-Tac
6032 179 A EFF CMD 2 Elfin Forest Command 2 Fire-Tac
6096
17d A EFF TAC 1 Elfin Forest Tac 1 Fire-Tac
6128 17f A EFF TAC 2 Elfin Forest Tac 2 Fire-Tac
6160
181 A EFF TAC3 Elfin Forest Tac 3 Fire-Tac
6192
183 A EFF TAC4 Elfin Forest Tac 4 Fire-Tac
KI6AOK
San Diego
I have also heard the North Zone Training tacs in use, so they should probably stay. I can confirm the Elfin Forest talkgroups are sporadically in use, usually for training, but also for incidents.
~ Laura
JoeyC
Senior Member
San Diego, CA
OK, how about these listed under Del Mar? Are these still in the plan?
5552 15b A DMR CM1 Fire Command 1 Fire-Talk
5584 15d A DMR CM2 Fire Command 2 Fire-Talk
5712 165 A DMR DSP Fire Dispatch Fire Dispatch
5904 171 A DMR TC1 Fire Tac 1 Fire-Tac
5936 173 A DMR TC2 Fire Tac 2 Fire-Tac
KI6AOK
San Diego
Well, Del Mar is dispatched by NorthComm, so that TG can probably be deleted. You would have to check with K6CDO regarding the others.
