Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > San Diego Metro Area Discussion
San Diego Metro Area Discussion - Local area specific discussion for San Diego and Imperial Counties.
Old 03-13-2018, 8:23 AM
Default North Comm 3A stuck mike?
Anyone know what’s going on with North Comm 3A today? Constant squelch breaks for the past 30 minutes and continuing. 3A appears to be patched with 4A, which is doing the same thing.
Old 03-13-2018, 8:36 AM
You didn't mention if this is a trunking system or not to those of us are not familiar with the system. But if it is, the dispatch consoles should show who the offending radio causing the problem is. someone in the dispatch center should be able to contact the person with that radio.
This is just another reason to enable the time out timer in all radios on a system. Doesn't matter if it is a convention system or a trunked system. The timer will shut down the stuck in transmit radio and release the system for use.
Jim
Old 03-13-2018, 8:38 AM
Hi, Jim:
It’s the San Diego County RCS trunked system. The dispatcher has tried to hail the offending radio, but the problem continues.
Old 03-13-2018, 9:13 AM
Finally corrected at 6:10 a.m.
Old 03-13-2018, 3:18 PM
K6CDO's Avatar
Laura,
Were you able to get the ID of the offending radio?
Don
Listening since 1966. 996Tx3, 996P2, 325P2 SDS100 WS1098.
Old 03-13-2018, 3:52 PM
Hi, Don:
No, sorry, I didn't. The stuck mike lasted well over an hour, though North Comm was able to transmit over it.
~ Laura
Old 03-13-2018, 6:21 PM
I heard it from 5AMish on...it was a repetitive kerchunk sound, at around 1 second interval, that kept the talkgroup locked up constantly. The kerchunk sounded like a quick key on a repeater that isn't long enough to activate the reverse burst TOC. It sounded like a system issue to me, as the intervals were to quick and evenly spaces.
Paul
Old 03-13-2018, 7:43 PM
I have heard this problem on 3A before, though only briefly, over the past few weeks.
Old 03-14-2018, 12:03 PM
K6CDO's Avatar
Thanks Laura and Paul.
Don
Old 05-20-2018, 1:04 AM
Back when I started in 2 way in 83 at Gifford engineering we had a customer whose system was CSQ.
The system got co channel traffic from LA that drove the dispatcher nuts, so she put a dictionary on the desk mic PTT switch to preserve her sanity.
jay thompson / CETsr, GROL
COML, COMT trainee
KC9VTT / COML DMAT CA-4
you must be really bored to be reading this far down
