Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > San Francisco Bay Area Discussion
San Francisco Bay Area Discussion Local area specific discussion for the San Francisco Bay area including the North, East and South Bays.
  #21 (permalink)
Old 02-27-2012, 3:24 PM
joen7xxx's Avatar
Are the green lights actually referenced in the Ca Vehicle Code or are they just ignored like here in Nevada where the mine vehicles use them to get around the Amber Light Permit and associated fees?
Sirens had motors.
Lights were glass
They drove it like they stole it!
$37.50 and a buck a mile.
  #22 (permalink)
Old 02-27-2012, 7:56 PM
These are fire trucks being referenced here, not mine vehicles. They aren't used for traffic alerting.
  #23 (permalink)
Old 02-28-2012, 8:22 AM
joen7xxx's Avatar
QUOTE: "These are fire trucks being referenced here, not mine vehicles. They aren't used for traffic alerting."
I realize this. I grew up in SF listening to KMA526. I was just asking since these are on motor vehicles operating on the public roadways, "are green lights actually referenced in the vehicle code".
Just curious.
Sirens had motors.
Lights were glass
  #24 (permalink)
Old 02-28-2012, 11:53 AM
From Google:
There are three sections in the CA Vehicle Codes that pertain to lights on a vehicle:
Section 25950 - V C Section 25950 Color of Lamps and Reflectors
Section 25951 - V C Section 25951 Direction of Beam
Section 24255 - V C Section 24255 Lighting Equipment Illuminating Device
  #25 (permalink)
Old 03-11-2012, 4:29 AM
Default It helps to actually look at the CVC
There is a whole chapter of the CVC devoted to vehicle lighting, starting with section 24250.
Flashing and Colored lights are covered starting with section 25250.
I don't see any reference to Green lights specifically being permitted, but Section 24003(c) might apply. It basically says that emergency vehicles may display lighting not otherwise permitted by the CVC as long as approved by CHP. (see also definition of 'department' in section 290)
Low intensity diffused lighting (<0.5 candella/square inch) is permitted in any color, but I don't think that applies here.
  #26 (permalink)
Old 06-10-2012, 3:03 AM
The green lights only identify the apparatus is an Aerial Truck, it helps drivers determine what rig is approaching them, then deploy accordingly.
  #27 (permalink)
Old 06-13-2012, 2:24 AM
Exsmokey's Avatar
Location: On the right side of California (geographical, not political)
One of my brother in law's is retired from the Lawrence Livermore National Laboratory and lives in Livermore. Back in the 1990's the Lab fire chief lived down the street and parked his chiefmobile on the street next to his house. He had a domed green light just forward of the center part of the light bar. I commented to my brother in law about never seeing this on any fire apparatus and what its function might be. At work he asked the chief what it was for and the answer was to show where the incident command post is at the fireground.
It's been quite a few years since this occurred and things might be very different now, including the use of the green light for this purpose.
Of course Sheldon (Big Bang Theory) would probably say it was to alert the "Green Lantern" that his help was needed.
Began as a donnowhatiwannabe, moved on to a wannabe, became abe, now I'm a wasabe.
"Using a drip torch is as much fun as you can have while standing up."
  #28 (permalink)
Old 06-13-2012, 8:41 AM
Green is still the color for incident command.
  #29 (permalink)
Old 06-13-2012, 9:11 AM
Send a message via Yahoo to sgtmatt
Green light signifies command post under NIMMS incident command structure
  #30 (permalink)
Old 06-13-2012, 12:36 PM
Yeah, I know NIMMS says that, SFFD actually tried to put green beacons on the roof of the command vehicles but that's another story. SFFD SOPs always put the Command Post IFO the incident building and because we don't want a Chief's buggy in the middle of the fire ground, it (the command post) is rather dynamic and may move as the wind blows. Chief's buggies and the Rescue Squad always park away from the incident, so as not to block any apparatus.
So just to clarify, the green light on the Aerial Trucks, is just to help Apparatus Operators, readily identify what type of vehicle is approaching (or behind) them. The second (or supply engine) would let the Truck go first, so they don't get delayed or blocked. The third engine, can easily see that a second supply is in progress, and would then go around the block, if possible, to supply from the other side.
Hey, it's San Francisco, we do everything different!
  #31 (permalink)
Old 06-13-2012, 7:24 PM
RolnCode3's Avatar
The VC pertains more to use. Our old friend, Title 13, is where all the standards are. The green lights are not an authorized color, so it is not technically a warning lamp. Title 13, Division 2, Chapter 2, Article 22, Section 816:
"Warning lamps shall meet the following limits in SAE J578d, September 1978. The color shall be that of the emitted light, not that of the material used for the lens or filter.
(a) Class A and D Warning Lamps: Red
(b) Class B, C, and E Warning Lamps: Red, yellow, or blue.
Note: Authority cited: Section 26103, Vehicle Code. Reference: Sections 24012 and 26103, Vehicle Code."
Here's the url: http://www.calregs.com/linkedslice/d...Action=Welcome
  #32 (permalink)
Old 06-24-2012, 11:51 PM
sffire's Avatar
The green light is not designed as a warning light to warn cars to pull over. They still have red lights to do that on rigs and buggies. Green light on the truck is not a warning light as defined. It is just for SFFD use. Just like the boat lights on top of the cab of truck companies. The truck is not a boat. It is only used to help guide the tiller operator line up the trailer with the tractor. You might say the green light and the boat light are to be used as guides.
Bearcat BC250XLT, Uniden BC346XT, BCD396XT, Radio Shack Pro-136. 162
  #33 (permalink)
Old 06-25-2012, 12:48 AM
RolnCode3's Avatar
It might as well be a disco ball. My only point was it doesn't qualify as a warning lamp. Use it however they want.
  #34 (permalink)
Old 06-25-2012, 11:53 PM
sffire's Avatar
You're correct, it is not a warning light.
