Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > California Radio Discussion Forum > San Francisco Bay Area Discussion
San Francisco Bay Area Discussion - Local area specific discussion for the San Francisco Bay area including the North, East and South Bays.
  #381 (permalink)
Old 07-14-2017, 1:06 AM
mibzzer15's Avatar
Originally Posted by Oakland_Tower View Post
Hayward is still dispatching their own FD using TG 2255. They were dispatching on Command 13, so maybe they are using this as their Tac. I doubt they would use the county Tacs since they are dispatching themselves.
Yeah you might be right, I thought I was hearing some Hayward traffic on some different channels but I might've been wrong.
BCD996XT, BCD396XT, and GRE PSR-300. I listen to mainly Fremont Fire and Fremont Police Department.
  #382 (permalink)
Old 08-18-2017, 6:46 PM
Has anyone figured out how to get away from the dreaded issue of scanners not fully receiving this system? I don't want to use a Yagi. I tried taking about a 1/4" piece of bus wire to use as an antenna, thinking it would be nearly deaf, and yet I'll pick up radio traffic but not always the full conversation. I'm up by Muir Station Plaza in Martinez. I also saw where someone used an unofficial updated firmware and their scanner is working great. I've got the GRE PSR-500 and the factory firmware. Any insight would be greatly appreciated. I miss listening to my local first responders.
Kind Regards,
Scott
N6UUH
Scott
N6UUH
  #383 (permalink)
Old 08-19-2017, 1:29 AM
qc's Avatar
qc qc is offline
Hi Scott unfortunately most likely going to use a Yagi antenna I use this one and I'm in Concord 824-960, 13dBi, Terrawave Yagi Base Antenna | Scanner Master the new receivers handle the Simulcast digital distortion https://wiki.radioreference.com/inde...tal_distortion better but the older scanners are going to have to have some sort of a directional antenna for base use good luck
Shon KJ6FNN
73
  #384 (permalink)
Old 08-19-2017, 9:17 PM
I have a question tgid 7205 was shared by El Cerrito police and San Pablo Police, but now El Cerrito has merged with Richmond PD dispatch 1 tgid 7505 and San Pablo channel that they share what El Cerrito is now dead no activity, does San Pablo have their own channel by themselves now that's new.scanner is a uniden bcd436hp
  #385 (permalink)
Old 08-19-2017, 11:43 PM
kma371's Avatar
Global DB Admin
There website lists a new emergency number. It is the same as pinole. Try their talk groups.
  #386 (permalink)
Old 08-19-2017, 11:48 PM
kma371's Avatar
Global DB Admin
And, their facebook says they are dispatched by richmond, so maybe they both went to Richmond.
  #387 (permalink)
Old 08-20-2017, 2:41 AM
Hercules,pinole,now dispatch san pablo pd
  #388 (permalink)
Old 08-20-2017, 11:52 AM
kma371's Avatar
Global DB Admin
Where did Kensington go? They were el cerrito as well.
  #389 (permalink)
Old 08-21-2017, 9:26 AM
phone_guy's Avatar
San Pablo PD went to their own channel.
El Cerrito went to RPD channel 1
Kensington went to Albany PD
  #390 (permalink)
Old 08-21-2017, 9:45 AM
Kind Regards,
Scott
N6UUH
I live in the East Bay and wrestled with the reception problem for a long time. Using my Radio Shack PRO668, I found that the only functioning solutions were either changing location (some areas worked better that others) or using a directional antenna like a yagi or corner reflector. While using the corner reflector at home, I found that I did better with it mounted two feet above ground than high in the air.
  #391 (permalink)
Old 08-21-2017, 2:51 PM
What channel did san pablo go to
  #392 (permalink)
Old 08-21-2017, 7:51 PM
When will the data base be updated
  #393 (permalink)
Old 08-22-2017, 9:16 AM
kma371's Avatar
Global DB Admin
When we get confirmation because one person says they are Richmond, one person says their own channel.
Only way to tell for sure is the good old fashion way of searching and trying to find out.
  #394 (permalink)
Old 08-22-2017, 10:47 AM
Right that makes sense thanks
  #395 (permalink)
Old 08-22-2017, 7:16 PM
kma371's Avatar
Global DB Admin
Since you are in San Pablo, I nominate you to listen and find out
  #396 (permalink)
Old 08-22-2017, 8:01 PM
So the scanner will automatically pick up a new talk group
  #397 (permalink)
Old 08-22-2017, 8:06 PM
kma371's Avatar
Global DB Admin
Oh, the good old days of searching appear gone
It's not really automatic. Need to put it into search mode and look/listen for new talkgroups.
  #398 (permalink)
Old 08-22-2017, 10:17 PM
I have the uniden bcd436hp scanner
  #399 (permalink)
Old 08-23-2017, 12:16 AM
kma371's Avatar
Global DB Admin
Ok.
  #400 (permalink)
Old 08-26-2017, 6:09 PM
Anyone else hearing DTMF tones on tg 2434 on the NW site?
Tags
ebrcs
