Go Back   The RadioReference.com Forums > Topic Specific Forums > SATCOM - Space and Satellite Monitoring Forum
SATCOM - Space and Satellite Monitoring Forum Forum for the discussion of the Space Shuttle, Satellites, Military Satcom, and Amateur Radio Satcom communications.
Old 10-03-2012, 11:53 PM
Default Mystery SS signal on 243.820
I've noticed a relatively weak, 40KHz or so wide signal centered around 243.820. It appears to be spread spectrum, and has a bearing roughly to the south from Philadelphia. I'm not sure if it's terrestrial or not. It's been there for at least the last few days (when I first looked).
Anyone else see this?
Old 10-04-2012, 12:43 AM
mancow's Avatar
It's a ss signal from one milsats. It's often referred to as water droplets due the sound when monitoring it in ssb mode. I don't know if it ever stops. It seems to always be there.
Old 10-04-2012, 10:15 PM
Ah, I guess one of the Milstar birds then? Thanks
Old 10-04-2012, 11:02 PM
Rt169Radio's Avatar
What kind of radio are you using to listen to it?
Old 10-04-2012, 11:27 PM
mmckenna's Avatar
Very weak here in Northern California, but likely that's because I'm listening to it on a discone. Interesting noise, I hear the "raindrops" on SSB. Kinda cool.
Old 10-05-2012, 1:20 AM
Originally Posted by rt169radio View Post
what kind of radio are you using to listen to it?
r&s pr100
Old 10-05-2012, 1:25 AM
Thanks all.
After doing a bit more checking and taking a more careful bearing, I'm now concluding that this is probably Milstar1-F1, at 39W.
After averaging the signal for a while., It seems to be centered at about, 243.8195, and is about 57KHz wide. Definitely spread spectrum.
Here's a spectrum snapshot showing the (instantaneous) signal: http://www.crypto.com/misc/uhf-sats/2438195.jpg
