Go Back   The RadioReference.com Forums > Topic Specific Forums > SATCOM - Space and Satellite Monitoring Forum
SATCOM - Space and Satellite Monitoring Forum Forum for the discussion of the Space Shuttle, Satellites, Military Satcom, and Amateur Radio Satcom communications.
Old 02-01-2013, 4:28 PM
Markb's Avatar
Default EAM's via SATCOM?
Hello all.
In addition to my newfound interest in UHF SATCOM, I've been doing more HF listening. As a result, I've studied up some on EAM's and have learned (but suspected at the same time) that
they are also delivered via SATCOM as well as numerous other media. Has anyone here ever heard an EAM via UHF sats or been able to correlate an encrypted signal to an EAM? Understandably, they could be sent via some other MILSAT on a different band.
Just curious.
Old 02-01-2013, 4:39 PM
mancow's Avatar
Never heard one
Old 02-01-2013, 6:56 PM
Markb's Avatar
I figured most likely not, since someone would have posted it in their logs or on this forum, but thought I'd ask anyway.
Thanks,
Old 02-05-2013, 3:20 AM
jsoergel's Avatar
Send a message via AIM to jsoergel Send a message via MSN to jsoergel Send a message via Yahoo to jsoergel
They are almost certainly sent via MILSTAR...since that's more or less why it's around to begin with. The UFO sats also have a dedicated wideband channel for it, but I've never checked which one.
Jared Soergel (Twitter: @jsoergel949)
Radios: BCD396XT, IC-R20 (x2), BC355N, PRO-76
Spotting gear: Canon EOS Rebel XS and EOS Rebel T2i, 18-55mm and 75-300mm lenses
Old 02-06-2013, 10:46 PM
Hooligan's Avatar
Send a message via AIM to Hooligan Send a message via Yahoo to Hooligan
Look up AFSATCOM & Giant Star.
I am the King of All Monitoring.
Old 02-09-2013, 4:33 PM
Hooligan's Avatar
By design, EAMs are sent out via redundant communications systems, wireline & RF, but it doesn't really matter how an EAM is received, as long as it's properly formatted, decoded & authenticated. Primary EAM distribution systems have to be certified by the JCS in terms of their reliability & speed, and while SATCOM has been in use for a long time, it wasn't necessarily considered to be a primary EAM distribution method until towards the end of the Cold War when the high-tech SATCOM systems were deemed reliable enough.
Best way to research the use of SATCOM for EWO/EAM stuff is to examine the comms capabilities of the strategic nuclear forces -- bombers, missile alert facilities, & SSBNs. All have had UHF SATCOM capability --at least receive-- for decades. Specifically, the B-52s & even FB-111s as well as Minuteman ICBM launch control capsules had AFSATCOM terminals for receiving SAC 'Giant Star' data traffic (mostly 244MHz), while ideally also receiving it via HF voice & the Survivable Low Frequency Communications System as well as several voice/data mode wire-based systems.
The SATCOM systems for the Minuteman force was greatly improved, first with a 'soft' SHF-based system (that, & other redundant comm systems caused them to stop using HF/SSB at most Minuteman sites) & now a hardened EHF system. The B-2s also have have EHF capability long enough to where it's now being upgraded & you'll notice you don't see any bulbous antenna like you do on the E-4B or E-6B aircraft.
The communications teams that travel with the National Command Authorities use SATCOM extensively when mobile or out in the field secure Iridium or Inmarsat, secure UHF satcom, and secure EHF terminals for primary voice connectivity & access to things like the Global Information Grid & specialized NCA/MEECN stuff.
