D
DaveNF2G
Guest
Win96 has spaces for 6 trunking tables (entries 0 through 5) under multi-tables.
A local VHF trunked network is transmitting 8 trunking tables over the control channels. The extra tables are the default Table 0 for 850 MHz and Table 1 for 760 MHz.
If I were to enter the 6 VHF tables only as Table 0 through Table 5, would the scanner be able to track this network properly?
The reason I ask is that PRO96COM designates each channel in the format ##-####, where the first two numbers before the dash seem to indicate which trunking table is in use. Will the PRO-96 rely on matching channel designators with the trunking table's position in its internal list?
