Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 04-17-2008, 1:43 PM
DaveNF2G's Avatar
Question Win96, PRO-96, and trunking tables
Win96 has spaces for 6 trunking tables (entries 0 through 5) under multi-tables.
A local VHF trunked network is transmitting 8 trunking tables over the control channels. The extra tables are the default Table 0 for 850 MHz and Table 1 for 760 MHz.
If I were to enter the 6 VHF tables only as Table 0 through Table 5, would the scanner be able to track this network properly?
The reason I ask is that PRO96COM designates each channel in the format ##-####, where the first two numbers before the dash seem to indicate which trunking table is in use. Will the PRO-96 rely on matching channel designators with the trunking table's position in its internal list?
David T. Stark
NF2G WQMY980 KYR7128
Old 04-17-2008, 2:29 PM
If the system is all VHF, and never uses any 850 or 760 MHz voice frequencies, then you can leave those entries out.
The PRO-96 doesn't use, directly, the "table identifier". Instead, it uses the 16-bit "channel" field in the call grants/updates as an explicit channel number (according to the P25 docs, that 16-bit field is really broken into two sub-fields: a 4-bit table identifier and a 12-bit channel number).
This is why you have to use the "channel Hi" and "channel Lo" values when entering data for the PRO-96. The scanner takes the 16-bit channel number in the grant and compares it to those 2 fields in each of the 6 table entries. As soon as it finds an entry that "contains" the target channel number, it uses the entry's base/offset/step values to calculate the voice frequency.
Each P25 "table identifier" represents 4096 consecutive, 16-bit channel numbers: table 00 = channels 0 - 4095, table 01 = channels 4096 - 8191, etc.
The order in which you enter the data in Win96 is not important. The PRO-96 doesn't use the "index" at all. Instead, as mentioned above, it does explicit comparisons using each entry's "Lo" and "Hi" values.
Old 04-18-2008, 9:49 AM
DaveNF2G's Avatar
Thanks, Don! That simplifies things.
As you pointed out in the other thread, ordinarily I don't need to enter tables, but I am testing the known tables from a particular network on a site that is not decoding properly.
David T. Stark
Old 03-21-2013, 2:56 AM
Default Question on StarSoft PRO-96 Programming
I have the StarSoft program to load my PRO-96.
I believe I am close to getting the info to my scanner.
I can NOT find in the help the answers to these questions:
WHEN I GO TO IMPORT INFO FROM RADIO REFERENCE I GET A PAGE WITH THESE ITEMS TO FILL-IN. CAN ANYONE BRIEFLY TELL ME W-H-A-T I NEED TO PUT IN THESE BLANKS?
TARGET BANK-?
BANK NAME-?
FIRST TARGET CHANNEL-?
FIRST TARGET TALKGROUP SUBBANK-?
FIRST TARGET TALKGROUP-?
PLEASE do NOT respond with, "Read the directions."
I have and IF it's there-I DID NOT FIND IT.
I APPRECIATE any info.
THANKS!
