Old 04-23-2008, 06:39 PM
Default Butel ARC996 Quick Key
I have several Motorola Trunked Systems that I am wanting to program into my 996. I have assigned the individual site for each system with a quick key. It shows up on the quick key column on the left (when I expand to show the site). It also appears when I select overview of system quick keys. However, for some reason when I select send data to the scanner it shows that that system has no quick key assigned and when I send the data no quick key is assigned. I don't understand what I am doing wrong. I know I have done it before (about a year ago) and I don't remember any problems. I have updated both the 996 and the Butel Software (v.2.10), and the situation has not changed. For some reason when I use the program and download a trunked system from RR I can select what quick key I want assigned and it seems to work. I would just do this but I have an extensive system programing already in place and just want to assign a quick key. Anyone have any suggestions?
Also does anyone have any experience with the updated Butel 996 program? It seems to be missing come features the old version had.
Ben -- KI4SMS
Old 04-24-2008, 04:16 PM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
In the 996 quickkeys are assigned to sites not trunk systems. So that's why in the Senddata window there is no qkey shown next to the trunk system(s). This is the same as in previous releases.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 04-24-2008, 08:22 PM
How do I get to the program setting in the new program. I have to seach and open the profil I want every time I log on, etc. Thanks.
Ben -- KI4SMS
Old 04-26-2008, 10:36 AM
Which program setting or you referring to?
Gommert
Old 04-27-2008, 10:07 AM
Thanks for your reply. If I remember correctly there was a settings page (perhaps in the Help section). There you could tell the program what to do when you hit enter, control, or to always open the last profile you were working on, etc. I cannot find this page.
Also as I have said, I assign a trunked system a quick key, however, then I press (send data to scanner) the group shows up without a quick key and one is not assigned when I send the data. I am not sure what I am doing wrong. When I download a system from this site and assign a quick key then it seems to work just fine.
Thanks for your help.
Ben -- KI4SMS
Old 04-27-2008, 02:13 PM
Select Setup _ Software Options.
You can not assign a quickkey to a system, you can only assign a quickkey to a site that belongs to a system.
Gommert
Similar Threads
Butel Software Updates ARC15; ARC996; ARC3500 500C1 Scanner Programming Software 4 04-04-2008 05:35 AM
996 Quick Key Problem jmays Uniden Scanners 10 01-30-2008 10:52 AM
help with BCD996T tulsascan Oklahoma Radio Discussion Forum 4 08-23-2007 08:21 AM
BC-15 GRP Quick Key Question chief21 Uniden Scanners 2 05-26-2007 11:43 AM
BCD996T Multi-Tower = Quick Key ? safetyobc Uniden Scanners 2 02-11-2007 05:29 AM
