In the software the closed box, you can also close the bank manually
http://myweb.cableone.net/marksscann...ml#open_closed
If you do it through the software you just have to reload the system into the scanner
Another thing you can do is simply lockout the TGID's you don't want when they become active on the scanner. Simply push the L/OUT button
